trans question
Old Jul 1, 2006 | 04:09 PM
JJ's civic's Avatar
Default trans question
how many bolt are they to unbolt the trans from the engine?
Old Jul 1, 2006 | 04:12 PM
JJ's civic's Avatar
Default Re: trans question (joeny12985)
plese i need to get it out before it gets dark
Old Jul 1, 2006 | 04:18 PM
SVOboy's Avatar
2 starter, 5 housing, 2 flywheel cover plate.
Old Jul 1, 2006 | 04:20 PM
JJ's civic's Avatar
Default Re: (SVOboy)
o the start hold it in too arite. i'll take those out now and see what happen wish me luck
Old Jul 1, 2006 | 04:26 PM
SVOboy's Avatar
I figured that's what you were missing, my first tranny removal experience I didn't know that, it got dark, and I had to give it up,
Goooood luck.
Old Jul 1, 2006 | 05:17 PM
JJ's civic's Avatar
the motor and tranny are apart but i can't lift the motor out i dont knwo what's holding them together HELP.
Old Jul 1, 2006 | 05:21 PM
SVOboy's Avatar
Is this in the engine bay? You can't really take the engine out without the tranny because the input shaft on the tranny pokes out quite a bit.
Old Jul 1, 2006 | 05:23 PM
JJ's civic's Avatar
i can't get the vss off and the tranny is already unbolted i'm jsut goint to unbolt the tranny motor and try to move i over and see it that work be back soon to update.
Old Jul 1, 2006 | 05:24 PM
SVOboy's Avatar
You can take the cable off the vss without pulling the vss.
Old Jul 1, 2006 | 06:09 PM
JJ's civic's Avatar
the engine is OUT hell yea i'm so happy. all i did was take the tranny mount near the battery off and the mount in the front. i'll put them back on tomorrow it's dark and i'm getting eaten alive. but i have to go out and pick up outside be back in a few.
Old Jul 1, 2006 | 07:51 PM
JJ's civic's Avatar
Default Re: (joeny12985)
i can't get the vss off the trans is there another way to get it off? or disconnet it i try to move it with the mtor in couldn't get it so i tryed to pry it out and snap a little off the lip should i try to turn it agin now that i can get to it better with out the motor in the car?
Old Jul 1, 2006 | 08:13 PM
SVOboy's Avatar
You should be able to just pull the cable out unless you want the whole vss out, which is difficult...try penetrating fluid and gripping the very bottom and wiggling side to side.
Old Jul 2, 2006 | 10:39 AM
JJ's civic's Avatar
pull it out of where just pull the wire out?
Old Jul 2, 2006 | 10:42 AM
SVOboy's Avatar
Yeah, I sold my cable so I forget what it looks like exactly, , but I'm pretty sure the cable just yanked out of the vss, or screwed, or something simple.
Old Jul 2, 2006 | 11:30 AM
JJ's civic's Avatar
how do you take the cluth off the motor? i'm tryong to put my engine on a stand
Old Jul 2, 2006 | 11:33 AM
SVOboy's Avatar
There are 6 or 8 (I forget) bolts around the outside of the pressure plate, they're either 10mm or 12mm, low torque, 12 point, take it off, the disc will fall off, and then if you need to the flywheel has 6 17mm 12 point bolts.
Old Jul 2, 2006 | 11:53 AM
JJ's civic's Avatar
dammit i dont have any 12 points and my 6 point isn't working
Old Jul 2, 2006 | 11:57 AM
SVOboy's Avatar
Go get a set for 10 bucks or whatev, very helpful, flywheel bolts you need to try your luck or use air tools. I got a set off once by bracing the engine and stomping on a wrench...I wouldn't reccomend it though.
Old Jul 2, 2006 | 01:33 PM
MANDO6669's Avatar
air tools rock!!!!
Old Jul 2, 2006 | 01:34 PM
MANDO6669's Avatar
if you cant get em though you can break it loose by hitting the end of the wrench with a hammer a couple of times ... you dont even have to hit that hard.
Old Jul 2, 2006 | 01:39 PM
SVOboy's Avatar
It's the truth, just make sure you don't strip the heads,
Old Jul 2, 2006 | 03:52 PM
JJ's civic's Avatar
i'm just going to put the engine on the stand the right way lol i just have to go and get new bolts
rice a roni
11
Apr 26, 2006 05:10 PM
streetlegal gocart
Feb 17, 2005 05:18 PM
Shaun
Apr 8, 2003 07:49 PM
stRtypR25
Dec 20, 2002 01:35 PM
hybridcrx
Feb 28, 2002 04:38 PM
