OBD1 valve cover, how should I ground it?
Old Jul 1, 2006 | 02:39 PM
SVOboy's Avatar
Default OBD1 valve cover, how should I ground it?
Swapped covers but there's no threaded hole for the second part of the ground like there was on the old cover, what should I do?
Old Jul 1, 2006 | 02:48 PM
fireant's Avatar
Default Re: OBD1 valve cover, how should I ground it? (SVOboy)
If there is a bolt on the other side of the cover somewhere for a spark plug wire bracket you could use it as an independent ground to somewhere close by... or straight to the battery.
Old Jul 1, 2006 | 02:52 PM
Fobtions's Avatar
Default Re: OBD1 valve cover, how should I ground it? (fireant)
just snip it off.
Old Jul 1, 2006 | 03:35 PM
Pee Wee's Avatar
Default Re: OBD1 valve cover, how should I ground it? (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">just snip it off.</TD></TR></TABLE>
Old Jul 2, 2006 | 03:58 PM
SVOboy's Avatar
Went out for a test drive and the battery died and then it began to storm badly so I tried my best not to die on the way home in a dark thunderstorm with no lights. I'm putting the old valve cover back on tomorrow...
Old Jul 2, 2006 | 04:26 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">just snip it off.</TD></TR></TABLE> Circumcise it, let me offer you a picture of my OBD-1 ground setups -
Nay a hickup. If your battery went dead that is a seperate issue.
Old Jul 2, 2006 | 04:28 PM
SVOboy's Avatar
The only other thing I did was extend my purge solenoid wires and put on a different plug so I could use the one mounted on my IM.
What would it randomly start doing that **** for...
EDIT: my valve cover doesn't have a spot on there like yours does, on the corner, that is.
Old Jul 2, 2006 | 04:30 PM
Default Re: (SVOboy)
It has to be something else if the car started by died along the way. Make sure the ground for the battery is minty fresh so that mid-way through your drive it isn't losing contact.
Old Jul 2, 2006 | 04:38 PM
SVOboy's Avatar
Well, the way it acted was that it gradually lost charge until it no longer had charge. I just went out and started it and it seemed fine and everything was full power, but as I left it idling the battery light slowly came on, I checked the alternator belt and it was fine.
I extended those wires, did the valve cover, and removed the holder for the old solenoid from the firewall. I had my vss ground to it through the bolt to the firewall, so I just put the wire inbetween the bolt and the firewall to leave it grounded, could that be the cause? I'm just going to put everything back exactly the way it was tomorrow, I guess.
But, now that I remember I drove the car earlier in the day after the changes and had no issues. I dunno now,
BrianDelSol
Jan 10, 2011 06:44 PM
Razr2
Oct 15, 2008 06:31 AM
2wheelhunter
Sep 13, 2007 06:34 AM
yoffer
Jun 14, 2007 11:18 PM
integlspwr01
12
Oct 13, 2003 11:16 PM
