gsr secondary butterfly signals
Old Jul 1, 2006 | 01:36 PM
808jdm_profileEG6's Avatar
Default gsr secondary butterfly signals
I had a gsr turbo hatch.the secondary butterflies never had the vaccuum on.So vtec would kick harder one time I guess.Now I just bought a stock gsr the vauum is hooked up but I was wondering if I got a vtec controller,would it trigger the secondaries too? Or even if a got a single stage vtec chipped ecu would that send the signal as well? Or would I have to cut the signal wire for the secondaries and tap it t0 the vtec solenoid signal wire?
Old Jul 1, 2006 | 02:24 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: gsr secondary butterfly signals (808jdm_profileEG6)
I run my butterflies with an RPM switch. Only the P72 ECU has the transistor to operate the butterflies. (I think there is a Prelude ECU that can do this too, but it won't work for Integras.) BTW: The butterfly solenoid output is independent of the VTEC solenoid output. With the stock cams, the butterflies should open after the VTEC is already operating.
vtecn8ive
Apr 20, 2006 09:14 PM
davken1102
Aug 2, 2003 06:01 PM
redhnda
Feb 3, 2003 09:29 PM
White S2k
Oct 31, 2002 01:17 AM
