brake and pulling problem
Old Jun 27, 2006 | 03:35 PM
nightrider81's Avatar
Default brake and pulling problem
when i brake now my car pulls to the left most of the time but sometimes it does it to the right. When i try to take off really fast it pulls to the left and then tries to pull to the right. Once in a while i feel that the brake pedal gets soft then hard again. Also when i hit pot holes on either left or right it pulls to that side. WHAT COULD BE THE PROBLEM?
Old Jun 27, 2006 | 06:03 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: brake and pulling problem (nightrider81)
It could be your wheel offset (aftermarket wheels) or wide tires.
Old Jun 27, 2006 | 07:49 PM
Default Re: brake and pulling problem (Dogginator)
do you think the spacers would help?
Old Jun 28, 2006 | 03:58 AM
Dogginator's Avatar
Daisy... Daisy...
Spacers would probably worsen your problem. Are your wheels stock?
Old Jun 28, 2006 | 04:43 PM
no the wheels are not stock. Another problem im having is rubbing on the inside. Someone told me to bang out the wheel well. But what do i bang out i dont want to hit anything else.
Old Jun 28, 2006 | 05:14 PM
Dogginator's Avatar
Daisy... Daisy...
Post you wheel specs (width and offset) and tire size.
Old Jun 29, 2006 | 05:17 PM
ill have to see what the off set is but the tire size is 205/45/16.
Old Jul 1, 2006 | 02:53 PM
i fixed the problem. I needed an alignment, and my left front caliper was locking up and heating up. So when i took the caliper off i just greased it up and put it back together and that fixed part of the pulling problem. Then i did the alignment.
eg6_danny
Feb 27, 2011 12:18 PM
candysnow007
Jul 1, 2008 06:41 AM
sireg6
Jul 14, 2007 09:53 AM
Axis-civic
Jul 19, 2005 08:50 PM
96tegls
Jun 27, 2004 12:07 AM
