B16 Shortblock & GS-R Head??
Old Jul 1, 2006 | 01:25 PM
dc2nick's Avatar
Default B16 Shortblock & GS-R Head??
I reciently had my 1996 OBD2 GS-R block bored over to ITR specs.
Brand New PISTONS, Rings, Bearings, Rod Bolts, Head Studs, Water Pump, Timing Belt etc.
It was running well, passed inspection with no CEL. Made it to 418 miles.
Then I was getting of the highway one day and I heard the dreaded KNOCK coming from under my hood.
So my engines knocking. Im assuming i SPUN a bearing.
Its gonna cost me ALOT more than I wanna pay to repair that.
I Found a JDM B16 Short Block for sale Localy. I kno my Head will fit, but my questions are...
Will my B18C1 Oil Pump fit the B16 block?
Will everything off my B18C bolt up to the B16 Block?
What Head Gasket do I use?
Do I need to run any type of Management or will my stock ECU be ok?
No I didn't Search because im in a VERY BIG HURRY
so please dont tell me to do so.
I just need it fixed ASAP.
Old Jul 1, 2006 | 01:45 PM
Babakarab's Avatar
Default Re: B16 Shortblock & GS-R Head?? (dc2nick)
man, your lazy, it will take less time if you search.
btw dont you have a warranty on the motor for xxxx miles
Old Jul 1, 2006 | 01:50 PM
dc2nick's Avatar
No warrenty. Im not even upset about the fucked up freshly built motor any more.
I just want it fixed.
and by searching, all I find is more topics telling People to Search.
Id rather just get answers.
I dont mean to be a dick, but id appreciate it if only people willing to help, post in this topic. Thanks
Old Jul 1, 2006 | 03:16 PM
Circuit Star-29's Avatar
Default Re: (dc2nick)
Everything is interchangable that you asked about. STock ecu will run fine.
Old Jul 1, 2006 | 03:40 PM
dc2nick's Avatar
Default Re: (Circuit Star-29)
I was told everything will work EXCEPT the oil pump.
Ill just buy a new one to be safe.
Old Jul 1, 2006 | 06:26 PM
teggywepower
Guest
Posts: n/a
what u should do is reverse the set up. Repair your gsr bottom end and slap a b16a top end on it. U will get more low end power and better high end toruqe
Old Jul 1, 2006 | 06:57 PM
96 GSR-T's Avatar
Default Re: (teggywepower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggywepower &raquo;</TD></TR><TR><TD CLASS="quote">what u should do is reverse the set up. Repair your gsr bottom end and slap a b16a top end on it. U will get more low end power and better high end toruqe</TD></TR></TABLE>
Dude are you retarted, he is not asking how to improve on his setup, if he wanted that info he would of posted the topic as " Blew my motor AGAIN, how do I make it better"
I would just buy a new oil pump for the peace of mind, you have gone through 2 motors now. And everything is interchangeable
Old Jul 1, 2006 | 07:37 PM
Dartanian's Avatar
How so? The B16 head flows worse and will result in a minor compression drop, not to mention that the cams suck *****.
Old Jul 1, 2006 | 07:52 PM
96 GSR-T's Avatar
Default Re: (Das Schmoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">
How so? The B16 head flows worse and will result in a minor compression drop, not to mention that the cams suck *****.</TD></TR></TABLE>
I believe you are wrong, the ITR/B16 head flows better, yes the cams suck ***** but thats why they make better ones
Old Jul 2, 2006 | 06:38 AM
dc2nick's Avatar
I know the B16 Head flows better, but I just got new valves, springs and retainers in my GSR head. and a skunk2 IM.
Today, Im planning on pulling my oil pan and looking to see what the actuial problem is.
If I damaged a Rod because of a spun bearing, ill replace it w/ the entire b16 bottom end.
If the rods and crankshaft are ok, ill just replace the bearings.
If the rods are ok, but the crankshaft is damaged, ill just take the crankshaft out of the b16 block and put it back in my GSR w/ new bearings. But mostlikley if the crankshaft is damaged, so is that specific rod.
anyone see anything wrong w/ those plans?
Old Jul 2, 2006 | 07:34 AM
yee SERIOUS's Avatar
i believe the oil pump differs because of the oil pan. one sits lower than the other. you don't want to deprive your motor of oil.
i'm pretty sure one of your bearings just let go. if your rod isn't bent, just change the bearing.
SL0-hatch
Aug 12, 2008 08:30 AM
hondachris1994
May 24, 2008 05:01 PM
egturbolsvtec
Mar 29, 2006 09:51 AM
brent_G
12
Mar 27, 2006 04:47 PM
Race Whore
Nov 9, 2005 08:09 PM
