header for a b18a
Old Jul 1, 2006 | 12:45 PM
em2ssm02's Avatar
Default searched searched: header for a b18a
as the title states, i have a b18a1 in my newly acquired 89 si and i want to get some power outta this bad boy,
i was wondering:
1: what would be a good brand im leaning towards DC (pricewise)
2: 4-2-1 or 4-1
3: if a 4-2-1 should it be 1 or 2 piece
4: what car should i buy the header for (for the fitment)
thanks
Old Jul 1, 2006 | 01:12 PM
em2ssm02's Avatar
come on someone has to know
Old Jul 1, 2006 | 01:54 PM
em2ssm02's Avatar
ttt
why is it that anyone who posts "HELP HELP swap gone wrong!!! HELP HELP", they get all the attention?
Old Jul 1, 2006 | 01:57 PM
Vantage's Avatar
just get the DC 4-2-1, its cheap and decent. IF your not going for a super if N/A setup it will work just fine. IMO 4-1 headers arent as good for a b18a as they are more for high RPM power, which a b18a cant take advantage of. 4-2-1 is more midrange/low end, where the b18a shines
Old Jul 1, 2006 | 02:44 PM
em2ssm02's Avatar
Default Re: (B18a_CRX)
ok but what application should i get this for?
Old Jul 1, 2006 | 02:54 PM
Vantage's Avatar
for the b18... you will probably also need to modify the exhaust to meet up to the downpipe.
Old Jul 1, 2006 | 02:56 PM
em2ssm02's Avatar
no man thats not what i mean, i mean what car. cuase dc makes it for all different types of cars and i wanted to know what type of car i should order the header for. sorry for the miscommunication
Old Jul 1, 2006 | 06:44 PM
Vantage's Avatar
order it for a integra. Most B-series are the same, to be specific, you need a header for a 90-93 integra LS or GS
Old Jul 1, 2006 | 10:52 PM
saaron34's Avatar
related question:
when you put on a header like this, you no longer use heat shields, correct? Wouldn't this be bad for the radiator fan, a/c plumbing, etc.? My b18's stock exhaust manifold sits so close to the condensor fan, you can barely fit a pinky in there. Is a DC 4-2-1 shaped differently to not be so close to these components? does it dissipate heat differently/more efficiently?
Old Jul 1, 2006 | 11:46 PM
Immanuel's Avatar
Default Re: (saaron34)
Ill sell you mine brand new never been used before DC 4-1 header for $300. Pm me if interested
Old Jul 2, 2006 | 07:11 AM
crxnj's Avatar
Default Re: searched searched: header for a b18a (em2ssm02)
Get a header for a 90-91 integra..I would get megan racing over dc sport personally ,,cheaper and better(imo)..Go with the 4-2-1 if you want low-mid rpm gains,,go with the 4-1 if you want mid-high rpm gains..Also ground clearance is better with the 4-2-1 header
Old Jul 2, 2006 | 11:18 AM
Vantage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saaron34 &raquo;</TD></TR><TR><TD CLASS="quote">related question:
Dont worry, clearances will be fine, the heat wont cause a problem.
Old Jul 2, 2006 | 11:22 AM
Jesterian's Avatar
24.243.141.75
Anyone run a megan racing 4-2-1 with the hasport a/c mounting bracket a/c setup?
Old Jul 2, 2006 | 05:36 PM
hbyrd8701's Avatar
Default Re: (Jesterian)
i have a dc 4-2-1 brand new still in the box, ill let it go for $200
Old Jul 2, 2006 | 05:42 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (hbyrd8701)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbyrd8701 &raquo;</TD></TR><TR><TD CLASS="quote">i have a dc 4-2-1 brand new still in the box, ill let it go for $200</TD></TR></TABLE>
stop hawking it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Get a header for a 90-91 integra..I would get megan racing over dc sport personally ,,cheaper and better(imo)..Go with the 4-2-1 if you want low-mid rpm gains,,go with the 4-1 if you want mid-high rpm gains..Also ground clearance is better with the 4-2-1 header</TD></TR></TABLE>
DC is bad I would agree bottom line though :both those headers do nothing.
You can make a ton more power off a 4-1 mid range if its setup right.
I'm more and more an elitest about headers more I research them.
You are correct mostly about the gernalazations but a well made header can be 4-1 or 4-2-1 and be great for whole band.
The "worst" header I'd put on my car is a Spark racing. I have a DC now it does nothing poor fit and bangs non stop. Did nothing over the OEM gsr exhaust mani I was running dnyo backs that, with a semi built motor.
If you really want to go N/A spark racing Bisimotor RMF etc. Comptech Greddy do make a tiny bit of power and pick up under the curve a fair amount. but really do you want to gain 3 peak for 400 or 10 for 500?
Thats your call.
Just my .02
Old Jul 2, 2006 | 05:51 PM
hbyrd8701's Avatar
Default Re: (***-assin)
the reason that im selling my header, is that im going to be boosting in a month or two, now i think $200 for my headers is a reasoning price.... still in the box.
Old Jul 2, 2006 | 06:30 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbyrd8701 &raquo;</TD></TR><TR><TD CLASS="quote">the reason that im selling my header, is that im going to be boosting in a month or two, now i think $200 for my headers is a reasoning price.... still in the box.</TD></TR></TABLE>
Thats great try for sale
Old Jul 7, 2006 | 04:57 PM
redDAinteg's Avatar
I have a used megan 4-2-1 header from my b18a in my da and im parting everything out. I'm letting it go for 120shipped. LET ME KNOW!!!!!
Old Jul 7, 2006 | 06:49 PM
davens's Avatar
em2ssm02: Try a little patience...3 posts in an hour, c'mon.
B18a_CRX: The 90-91, 92-93 and 94-01 are all different. As are the GS-R and LS. Quit passing on bad generalized info.
I ended up getting a 90-91 B18a header. It was 2" too long at the bottom and the bolt holes were not aligned the same way as my CRX cat.
So I did this:
Works fine but it would be easier if someone knew if here was a bolt on version.
Old Jul 7, 2006 | 10:29 PM
redDAinteg's Avatar
Default Re: (davens)
what you should do is get a 92-93 header because it is 2 inches shorter compared to the 90-91 header.
IgnitionZ055
Nov 24, 2008 05:09 PM
DARKTEG_
Aug 11, 2006 11:26 AM
DARKTEG_
Aug 10, 2006 03:15 PM
blk007
21
Apr 19, 2006 07:15 PM
jt-sport
Aug 26, 2003 03:57 PM
