MSD installation
Old Jul 1, 2006 | 07:46 AM
project 2two9's Avatar
Default MSD installation
what color wires go where?... how do u make the diizy cap for connecting the blaster coil?...
Old Jul 1, 2006 | 08:23 AM
DC2 Mang's Avatar
Default Re: MSD installation (project 2two9)
drill a small hole to fit the wire through
the old wires that connected to the internal coil, you have to cut the connectors off and splice the wires and add longer wires
the black wire in the ground so it connects to the negative terminal of the blaster, then take the two other wires (i think they are white) splice, and extend and connect that wire to the positive terminal on the MSD
you should be good to go
Old Jul 1, 2006 | 10:04 AM
96 GSR-T's Avatar
Default Re: MSD installation (DC2 Mang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">drill a small hole to fit the wire through
you should be good to go </TD></TR></TABLE>
^^^^ what he said, the wires coming out of the msd are pretty self expanatory, the red & black are power/ground, there is an orange and another color on mine that goes to the Blaster coil, and the only 2 wires left are a white and i forget the last that goes to the inside of the distributor. On another note for $30 I just bought the cap that had the spark tower already on it.
jspeedy
Jun 26, 2010 05:04 AM
vtek9
Aug 24, 2007 11:34 PM
JDM96SpecCTR
Nov 27, 2004 09:25 AM
Rod.
Jun 29, 2004 07:05 AM
Que_Lude
Sep 11, 2002 08:38 PM
