IACV code 14. tried almost everything to fix it.
Old Jul 1, 2006 | 01:25 AM
goofyej6's Avatar
Default IACV code 14. tried almost everything to fix it.
Hi there. I recently did a y7/y8 mini me and what i ever seem to try to do it keeps throwing that darn code. Its not a sporadic idle, but as soon as it throws the code it idles at a constant 1500 rpm +/- 100. Also if I give it a tiny bit of gas, it bucks. It feels like I would be pressing the gas and then letting off repeatedly even though I am just holding the accelerator steady.
Heres the thing also. If i turn off the car for a little bit to go inside and go out and start it and go some where, the CEL will still be on but it will idle fine. After I drive for 5-10 min it does teh same thing all over.
So far I have done the following:
Clean IACV w/ throttlle body cleaner.
Let the car idle w/o the radiator cap so air bubbles come out.
Did the click test from the ecu side. It does click so i assume its good.
Made sure the IACV wires are wired right, and they are.
Motor is a y7/y8 w/ y8 intake mani. Manifold has been taken off and the old gasket was cleaned off. Now using hondata w/ RTV sealent to make sure it is sealed. Any help would be greatly appreciated. This code is driving me nuts
Car is obd2b btw. and i did do the 3wire to 2 wire correctly using obd2b p2p also
Modified by goofyej6 at 3:46 PM 7/1/2006
Modified by goofyej6 at 2:35 AM 7/2/2006
Old Jul 1, 2006 | 02:06 AM
bks84's Avatar
Loved
I have hte same problem...
Old Jul 1, 2006 | 11:44 AM
goofyej6's Avatar
Default Re: IACV code 14. tried almost everything to fix it. (goofyej6)
ttt
Old Jul 1, 2006 | 02:20 PM
goofyej6's Avatar
heeeeelp meeeee
Old Jul 1, 2006 | 04:24 PM
goofyej6's Avatar
i pulled the iacv plug right after i started my car today and it doesn't surge. is it suppose to? and my idle adjust screw doesn't seem to do anything.
Old Jul 2, 2006 | 01:35 AM
goofyej6's Avatar
hellooo
Old Jul 2, 2006 | 02:39 PM
goofyej6's Avatar
ttt
Old Jul 2, 2006 | 02:44 PM
ProJectCvic's Avatar
check for vaccum leak..sound to me that that is the problem
Old Jul 2, 2006 | 03:57 PM
fmrprojects's Avatar
Default Re: IACV code 14. tried almost everything to fix it. (ProJectCvic)
you sure you have the correct plug in the sensor. there are three 2 wire plugs around that area, iacv, evap, and iat.
Old Jul 2, 2006 | 08:48 PM
goofyej6's Avatar
^ yes i'm am positive that i have the wires correct. anything else guys?
Old Jul 3, 2006 | 08:06 AM
bks84's Avatar
Loved
Default Re: IACV code 14. tried almost everything to fix it. (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goofyej6 &raquo;</TD></TR><TR><TD CLASS="quote">^ yes i'm am positive that i have the wires correct. anything else guys?</TD></TR></TABLE>normally the IAT wont reach...
Old Jul 3, 2006 | 02:41 PM
goofyej6's Avatar
Default Re: IACV code 14. tried almost everything to fix it. (4sd4dr)
ttt
Old Jul 3, 2006 | 04:14 PM
Junkie Si's Avatar
I threw this code a while back on my b16. I tried cleaning it and it never worked. I just replaced my IACV and it never threw that code any longer. My motor didnt have an iat, but i heard that there is a little screw that needs to be readjusted inside it for d series motors. You may have to do a search for that. Now the bucking, that is because the car went into safe mode. It feels really shietty but thats the way the ecu responds to that CEL code. Hope that helps.
Old Jul 3, 2006 | 05:12 PM
Default Re: IACV code 14. tried almost everything to fix it. (marcosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcosh &raquo;</TD></TR><TR><TD CLASS="quote">I threw this code a while back on my b16. I tried cleaning it and it never worked. I just replaced my IACV and it never threw that code any longer. My motor didnt have an iat, but i heard that there is a little screw that needs to be readjusted inside it for d series motors. You may have to do a search for that. Now the bucking, that is because the car went into safe mode. It feels really shietty but thats the way the ecu responds to that CEL code. Hope that helps. </TD></TR></TABLE>
you are thinking of the fast idle control valve.
Old Jul 3, 2006 | 06:20 PM
Junkie Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">
you are thinking of the fast idle control valve. </TD></TR></TABLE>
yeah thats it. thanks.
Old Jul 5, 2006 | 08:36 AM
patrick_yi_82's Avatar
My car does that too.
Cel 14, and reving 1500 RPM.
Thed IACV works fine, it clicks when I tested it. I cleaned it as well.
But did not work. I'm driving like that since.
Old Jul 5, 2006 | 04:52 PM
Junkie Si's Avatar
Default Re: (patrick_yi_82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick_yi_82 &raquo;</TD></TR><TR><TD CLASS="quote">
But did not work. I'm driving like that since. </TD></TR></TABLE>
Even if it clicks it can still malfunction. All it has to do is malfunction that one time and it would throw that code. The valve inside could be screwed up somehow.
Old Jul 22, 2006 | 12:20 PM
Takumi Fujiwara's Avatar
Default Re: (marcosh)
Anyone fix this problem yet? I'm suffering from the same symptoms but I know this IACV is good.
Old Jul 22, 2006 | 01:02 PM
igo4bmx's Avatar
damn i cant read
Old Jul 22, 2006 | 01:25 PM
Default Re: (igo4bmx)
nvm, I had the wrong plug on the IACV.... why don't they make every plug different for us idiots... lol
Old Aug 15, 2006 | 02:05 PM
focusoncivic's Avatar
Default help
I have the exact same problem honda said 185 be in on tuesday not totaly sure if its even shot... no one else have any input?
Old Aug 16, 2006 | 07:10 PM
Default help
JDM215
19
Jan 24, 2011 07:45 PM
92lxsleeper
16
Jun 12, 2009 06:38 AM
xd69
13
Jul 8, 2008 08:44 PM
Ser1N
12
May 25, 2006 09:15 PM
sleepyhamsterlx
Dec 10, 2003 07:43 AM
