AC What is the difference betweek eg and eg2(del sol)
I was wondering if a AC kit from a Del Sol w/ a b16 will fit a 92 civic 4dr w/ a d15? Has anyone done this before. The kit will come complete but if there any other brackets that I need from the ex model please let me know. Thanks.
<FONT COLOR="red">
The A/C condensor, compressor and accumulator is the same. On the D motors, the compressor bracket is the same is the same as any EG (OBD1)
For a B series motor into a del Sol using the del Sol/civic A/C parts, you have to get the compressor bracket off of a del Sol VTEC model, as it's specific to the del Sol since that model used the Civic A/C stuff. If you're swapping in a B from an EK Civic Si or DC and you want to use that A/C compressor and bracket, then you have to get a custom low pressure line done as the ends are different when connecting to the compressor. That's what I did.</FONT>
