Tps voltage a little off and jumpy idle.
Old Jun 30, 2006 | 08:18 AM
JasonST's Avatar
Default Tps voltage a little off and jumpy idle.
So I put an h22 into my integra a few weeks back and the idle is way too low, at warm, it's 200-400, extremly low, it won't die, but it feels like it wants to. I was wondering, anyone know what their tps sensor is set to? Mine's at .5 right now, I remember setting it at .45 but I think it moved a little, some guy said that his other car was set to .32V stock from the factory and when he set his tps to this it fixed his idle. I was just wondering does anyone know what your tps is set to? How many volts. Thanks.
Old Jun 30, 2006 | 09:22 AM
2lude4u's Avatar
Default Re: Tps voltage a little off and jumpy idle. (JasonST)
The normal reading with the T-body closed is .5v so that's fine.
Have you adjusted the idle using the "idle adjusting screw"? It's the screw on the top front portion of your OEM t-body that adjusts the amount of air going into the intake manifold at idle. By letting more air in it will raise your idle to around 800 rpm where you want it to be.
Old Jun 30, 2006 | 10:38 AM
JasonST's Avatar
Default Re: Tps voltage a little off and jumpy idle. (2lude4u)
Yeah I'm a little confused about the idle screw cause no matter which way I turn it, all the way to the left or right my idle doesn't seam to change. Any help would be great.
Old Jun 30, 2006 | 11:22 AM
TruNinja619's Avatar
try cleaning the IAC valve.. that should help out with your low idle...
turbohatch96y7
Engine Management and Tuning
Jun 10, 2013 07:42 AM
dth0ng69
Mar 7, 2009 11:21 AM
DC2*Integra
Sep 20, 2005 12:51 PM
daddymaxx
Dec 15, 2003 12:24 PM
steve_s
Jan 22, 2003 02:06 AM
