96 civic not going into gear
replaced the cv joint, and still wont drive, tranny fluid is fine, and clutch is tight. Starts fine, but rolls in gear, and now making a grinding noise under left side when accelerated in gear. Please help
sounds like the clutch is going out. you might want to also check to see if the clutch caliper is pushing out all the way.. you might have to take the air out of it. When you replaced the cv boot, did make sure that you used the proper bolts when you reassembled the brakes? You might have a wrong size bolt that is holding the brake (( that might be the noise you hear )). good luck hope this helpsl.
sohcpoweredeg
10
Oct 13, 2011 10:37 AM
Mario.
18
Dec 16, 2004 11:21 AM
Qwikrex
23
Apr 22, 2003 11:07 AM
