Car is drinking coolant :O !!!
Old Jun 30, 2006 | 02:48 AM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Car is drinking coolant :O !!!
ok i put some coolent in my radiator and i filled the back up res took my car around the block came back, like 5 mins later the coolent in res was ALMOST gone then another 3 more mins it was GONE !! What is goin on ???
Old Jun 30, 2006 | 02:31 PM
Default Re: Car is drinking coolant :O !!! (Evolution-93-Ex)
up for some answers ????
Old Jun 30, 2006 | 02:55 PM
.Slug's Avatar
coolant ferries? I would say there has to be a leak somewhere and the coolant leaking out is being captured somewhere else and not falling onto the ground, if you don't see any forming on the ground. I would say feel around during cold engine and look for coolant somewhere.
Old Jun 30, 2006 | 03:12 PM
mattssi's Avatar
I have seen the coolant line hooked to a small vacuum port before. the engine may be consuming coolant. is it smoking...
Old Jun 30, 2006 | 05:37 PM
Default Re: (mattssi)
no smoke, i think the engine is consuiming it too, cause it was crazy like 5 mins later all of it was gone i was like . Tomorrow i'm gonna have my cousin come over and we'll mess around with it.
Old Jun 30, 2006 | 05:48 PM
mikeycivic's Avatar
Default Re: (Evolution-93-Ex)
check your oil, may be head gasket
Old Jun 30, 2006 | 08:09 PM
Default Re: (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote"> check your oil, may be head gasket </TD></TR></TABLE>
check the oil ?
yea thats what i was kinda thinkin but i hope not
Old Jun 30, 2006 | 08:15 PM
axtran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">check your oil, may be head gasket </TD></TR></TABLE>
what the h*ll does engine oil have to do with coolant? it isn't mixing, or else there would be white/blue smoke...
sure there's no air bubbles? cuz if the system works it around and then the level dropped - you did nothing wrong, it just is clearing its own system. if your heater is hooked up, check under the dash for some leaking, could be bad heater core where it leaks out. if your temps are normal, i'm doubting its consuming because there would be tons of whitesmoke... and your engine should really give you all the signs if there's leaking coolant because it would be really messy and smell like antifreeze. good luck
Old Jul 2, 2006 | 12:48 AM
Default Re: (axtran)
Thanks bro !! I'm gonna prob flush my radiator and go through everything to see whats wrong when i get time.
Old Jul 2, 2006 | 01:11 AM
spoonracer84eg's Avatar
Head Gasket
Old Jul 2, 2006 | 04:20 PM
Default Re: (spoonracer84eg)
explain how its the headgasket ?? So i check oil the coolant and oil arent mixing so i check oil
Old Jul 2, 2006 | 11:31 PM
Turbo B18C EJ6's Avatar
if you cant see white smoke cvoming from yuor exhaust and yuor not seeing coolant leaking any where, its going into yuor oil pan. if you pull yuor diipstick it will be over full and look milky in color, thus coolant mixing with the oil. its leaking bewteen the head gasket and block and running into oil pan.
Barmaleyka
Acura TL, RL & ZDX
Jun 3, 2017 11:15 PM
Ayashifx55
Dec 23, 2010 10:01 PM
tallyBanned
Aug 18, 2006 08:50 AM
george34
May 7, 2006 07:09 AM
94gsr18kid
Dec 29, 2004 08:12 AM
