DC5 Type R Brembo 5 Lug Conversation
will this conversation work on the 04-05 em2 and is it worth it
it includes.......
Kit includes Front and Rear knuckles, trailing arms, calipers, rotors, pads, and ebrake cables,Front Aluminum Control Arms,front sway Bar.
it includes.......
You'd need to get custom Axles up front, because the K-series transmission is mounted differently than a D17. Also, you'd to roll the fenders, since the DC5-R has a wider stance than a normal DC5. The Control Arms are different.
You'd be better off just swapping for rear discs off an EP3, and getting an aftermarket brake kit. Unless you already swapped a K-series, then go for the DC5-R swap.
Also, you could use the Sway bars without an issue.
Would it be worth it? Not unless you're already swapping a K-series. Even then, it's still expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 05ex_vic_blk »</TD></TR><TR><TD CLASS="quote">will this conversation work on the 04-05 em2 and is it worth it
it includes.......
Kit includes Front and Rear knuckles, trailing arms, calipers, rotors, pads, and ebrake cables,Front Aluminum Control Arms,front sway Bar.</TD></TR></TABLE>
I really do not think you're going to find that it's worth the money in the long run.
If you want to do all that, you might find that purchasing another car in the first place would be the better thing to do, long term.
it includes.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">
I really do not think you're going to find that it's worth the money in the long run.</TD></TR></TABLE>
nothing done to our cars is "worth the money in the long run"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 »</TD></TR><TR><TD CLASS="quote">
I was referring to the long term perception of the fun quotient vs the money spent.
</TD></TR></TABLE>I was referring to the long term perception of the fun quotient vs the money spent.
h22-eg-hatch
May 9, 2015 07:53 AM
Sassafrass
Nov 20, 2003 04:04 PM
91hondacrx
Aug 23, 2002 08:14 AM
