Tune up Question...
Pullys don't need to be replaced unless they break, which is highly unlikely to happen.
You should change your timing belt, but you should check your alternator, power-steering, and AC belts to make sure they're not cracking/dry rotting. If those 3 are still good then don't worry about replacing them.
