2000 Civic Si bogging problems and stutters up to 3 or 4k rpm's!!!Plz help
Old Jun 29, 2006 | 02:16 PM
00EKcivic55's Avatar
Default 2000 Civic Si bogging problems and stutters up to 3 or 4k rpm's!!!Plz help
Ok, my car runs fine when it is cold before it warms up, then it will start to bog considerably yet will never die, then it seems just as it hit about 3 or sometimes 4 thousand rpms it wakes up and runs fine...what do i need to do to fix this?
Thank You
Old Jun 29, 2006 | 02:23 PM
Slamaccord's Avatar
Default Re: 2000 Civic Si bogging problems and stutters up to 3 or 4k rpm's!!!Plz help (00EKcivic55)
UMMMMMMMMM
Do you have a check engine light?
Old Jun 29, 2006 | 02:25 PM
littlegreenb18's Avatar
sounds like an ignition problem. check your cap, rotor, wires, and plugs. I've been there, it was my cap.
Default Re: 2000 Civic Si bogging problems and stutters up to 3 or 4k rpm's!!!Plz help (Slamaccord)
the check engine light use to come on sometimes, then go away after a while, but it did come on recently but only because i pulled out a secondary o2 sensor while it was running..i didnt hear her purrrring.
Old Jun 29, 2006 | 02:28 PM
Default Re: 2000 Civic Si bogging problems and stutters up to 3 or 4k rpm's!!!Plz help (littlegreenb18)
i replaced the wires with msd 8.5's and the spark plugs iridiums, there is absolutley nothing wrong with the cap, brand new, and the rotor is brand new too. I heard it could be my IAFC valve i believe is what is was called. could someone give me some info on the pcv valves????
Old Jun 29, 2006 | 02:31 PM
Slamaccord's Avatar
Sounds like a map sensor malfunction.
Have you check your timing?
Any recent work done to the car?
Old Jun 29, 2006 | 02:40 PM
my timing is where it needs to be at. Im not looking for backyard mechanics tips..Ive tried many things ive already thought were wrong, not seems to be working.....
Old Aug 14, 2006 | 04:54 AM
1sikhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00EKcivic55 &raquo;</TD></TR><TR><TD CLASS="quote">my timing is where it needs to be at. Im not looking for backyard mechanics tips..Ive tried many things ive already thought were wrong, not seems to be working.....</TD></TR></TABLE>
did u ever find out the problem with it? my car does the same exact thing and it really pisses my off.
Old Aug 14, 2006 | 12:50 PM
JDMish85's Avatar
It could be a number of things. I had the same problem on my 00' si. It sounds like either you need some new plug and wires, or a new distributer( whole assembley) Does your car have a swap in it?
Old Aug 14, 2006 | 01:05 PM
1sikhatch's Avatar
Default Re: 2000 Civic Si bogging problems and stutters up to 3 or 4k rpm's!!!Plz help (JDMish85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMish85 &raquo;</TD></TR><TR><TD CLASS="quote">It could be a number of things. I had the same problem on my 00' si. It sounds like either you need some new plug and wires, or a new distributer( whole assembley) Does your car have a swap in it?</TD></TR></TABLE>
yes its a 96 civic w/ a jdm b16 swap
Old Aug 26, 2006 | 09:44 PM
electric-boost's Avatar
bump, my car is also doing this!
in for a solution and back from the dead
Hondaiii3
Oct 13, 2011 10:09 PM
EvilGreenEyes
Sep 9, 2009 07:58 AM
dcsports
Dec 7, 2008 06:54 PM
h3rsh3y2001
Apr 12, 2008 05:07 AM
Carlito Brigante
Oct 15, 2002 06:10 AM
