S housing inlet machining - short radius 4" bend...
Old Jun 29, 2006 | 11:27 AM
timg's Avatar
Default S housing inlet machining - short radius 4" bend...
I have a couple of questions. Due to the packaging of my turbo setup, a normal 4" inlet on a compressor housing is out of the question. I'm currently running a 3" inlet and even it is a tight fit.
Can the S trim compressor housing (such as in a GT35R) be machined down for a 3" silicone connector?
Is there a 4" equivalent to this 3" short radius 90?
Thanks.
Tim
Old Jun 29, 2006 | 03:54 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: S housing inlet machining - short radius 4" bend... (timg)
ive had a few customers machine them down to 3" in the past
have you had any troubles with that rubber 90* bend on the inlet collapsing under load?
Old Jun 29, 2006 | 05:34 PM
timg's Avatar
Default Re: S housing inlet machining - short radius 4" bend... (Ken Peak)
Thanks. That's good to know. The 90 has never collapsed under boost. It's VERY thick and quite stiff. Even getting it on the turbo is a hassle due to it's stiffness- it doesn't really bend at all. It was a stocked Turbonetics part a few years ago, not sure if it's still in their catalog or not.
Have you guys done the machining, have you sent it out for someone else to do, or have your customers had it done by another third party? Thanks again.
Tim
Old Jun 29, 2006 | 05:44 PM
mrbsponge's Avatar
i want to say that the "precision" gt35R has an option of the 4 or 3 inch inlet, and thier compressor covers are .60 AR vice my regular garret model which is a .70AR "S" cover
Old Jun 29, 2006 | 05:57 PM
timg's Avatar
I noticed they have an E cover version. I thought about it, but I think I'd prefer a slightly larger outlet and a/r on the housing. The other things holding me back are that the backplate of their GT35RLE is different from the backplate on their GT35RLS and they don't offer a 0.82 or larger a/r on a T4 housing hotside. I may still wind up running their GT35RLE though.
Tim
Old Jun 29, 2006 | 06:03 PM
PeakBoost's Avatar
B*A*N*N*E*D
they had it machined 3rd party.
good thing that 90* is rigid.
i had some buddies call me on the dyno with a twin modular mustang setup and "couldn't make over 12lbs, no matter what..."
drove out, monitored the first run and noticed the 90* silicone inlets were collapsing as soon as the turbos would load up. just wanted to give you a heads up, in case you had an issue.
they changed em out for aluminum pieces and made ~550@12psi on a mustang dyno 1st run
Old Jun 29, 2006 | 06:15 PM
TypeSLO's Avatar
i can't help you much with the machining but looks like your manifold is awefully close to you radiator hose with no protection...
Old Jun 29, 2006 | 06:25 PM
timg's Avatar
It is. It's actually a few inches, but looks closer in the picture. It's been like that for 40k+ miles and a few years now.
Tim
Old Jun 29, 2006 | 07:02 PM
Muckman's Avatar
Moderator in Chief
I have a 4" S cover with anti-surge with this same elbo problem. Timg, what is the width of that elbo? from the inlet to the back.
Ken, how does one machine a 4" opening down to a 3"? You'd remove so much material there would be nothing left of the inlet.
Old Jun 29, 2006 | 08:22 PM
timg's Avatar
Default Re: S housing inlet machining - short radius 4" bend... (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I have a 4" S cover with anti-surge with this same elbo problem. Timg, what is the width of that elbo? from the inlet to the back.
Ken, how does one machine a 4" opening down to a 3"? You'd remove so much material there would be nothing left of the inlet.</TD></TR></TABLE>
I'm not sure what the measurements are right now. I like to order car parts when I'm traveling for work and spend all of my free time when I'm home installing them. If the car wasn't a few states away, I'd run out to the garage to measure it for you. This elbow from ATP turbo appears to be the same as mine.
http://www.atpturbo.com/Mercha...-90EL
Tim
Old Jul 3, 2006 | 09:17 AM
Muckman's Avatar
Moderator in Chief
I need a tight 4" inlet/outlet 90* elbo that has a max height of 6". ATP has a elbo like this but its 8" high. Can anyone help me out?
Old Jul 3, 2006 | 10:30 AM
DontBlink's Avatar
turbonetics has these for tight clearences
http://www.turboneticsinc.com/pa_nitrile.htm sizes are at the bottom of the page.
Old Jul 3, 2006 | 12:24 PM
timg's Avatar
Default Re: S housing inlet machining - short radius 4" bend... (DontBlink)
I think Turbonetics is where my first one came from. Unfortunately, they only have them for 3", not 4".
Tim
Old Jul 3, 2006 | 04:01 PM
karmadhi's Avatar
Now you guys got me worried, I made some plastic mold myself, its a thixotropic type for 4" turbo intake, its softer than normal hose, Im thinking itmight collapse and even be sucked in the ******* turbo
Old Jul 6, 2006 | 06:08 AM
Muckman's Avatar
Moderator in Chief
Default Re: S housing inlet machining - short radius 4" bend... (karmadhi)
Yeah I wouldnt trust that under extreme vacuum/heat.
Old Jul 6, 2006 | 09:53 AM
yee SERIOUS's Avatar
if you call or email atp, i think they rig something up for you. they got me this setup with 3inch rubber 90deg bend my regular t3/to4e
speeddave
Welding / Fabrication
Mar 29, 2008 02:18 AM
97Alex
12
Dec 17, 2007 07:46 PM
Quickgti1.8t
Jul 23, 2006 09:47 AM
PINKS
Dec 7, 2005 06:26 AM
Huee
Nov 30, 2004 09:34 AM
