eliminate in engine bay...pic
-can the charcoal can be elimintaed??
-how do i remove my abs so i can take it to go get painted do i just start unbolting or is there a way to remove it the right way???
The black canister underneath the battery try is the charcoal canister, it's part of the fuel/emissions system. I'm pretty sure the car will run better with it, and you would DEFINITELY need it to pass any emissions testing if done in your area.
You can remove the ABS unit, you will just have to unbolt all the hard lines and be careful you don't bend them. Then you'll need to bleed the system when you get the car back together, but I don't know really how to do it on the 94-97-year ABS systems.
just pull the charcoal canistor out, leave the metal line that goes to the gastank unplugged. the rest of the vacum lines u plug up.
abs is crap anyways, just get rid of it. https://honda-tech.com/zerothread?id=1547813
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsHoney84 »</TD></TR><TR><TD CLASS="quote">i thought we had a reciever/dryer located on the driver side near the headlight.
feel free to correct me if im wrong</TD></TR></TABLE>
well yes there is, but that wasn't mentioned in the original post.
jagged4698
May 13, 2009 09:58 PM
