Water temp gauge install
Old Apr 18, 2002 | 08:35 AM
speedymon's Avatar
Default Water temp gauge install
Is it alright to install the water temp sender wire by splicing into the ECT. Or do i have to drill a hole in the thermostat housing. Which is more accurate?
Old Apr 18, 2002 | 10:06 AM
Spade's Avatar
Default Re: Water temp gauge install (speedymon)
I would drill the hole before the Thermo.......that way you get actuall engine water temp.
Old Apr 18, 2002 | 01:25 PM
Jayson S.'s Avatar
Just remove your stock temp sender from the head and use the sender that should have come with gauge.
How do you know the ECT or stock sender will work with your aftermarket gauge??
All I did was run the two wires from gauge to sender located on head.
Easy as pie! mmmm pie
Anyways, good luck.
Jayson S.
Old Apr 18, 2002 | 09:42 PM
speedymon's Avatar
Default Re: Water temp gauge install (Jayson S.)
Anyways, good luck.
Jayson S.
And this is giving you accurate readings?
Old Apr 19, 2002 | 09:50 AM
Jayson S.'s Avatar
Yes using the temp sender supplied with the aftermarket gauge and running the ground and sensor wires from sender to gauge worked perfectly. I get 100 percent accurate readings.
All I did was follow the Autometer gauge install diagram.
Jayson S.
Old Apr 30, 2002 | 08:43 AM
speedymon's Avatar
Yeah i spliced into the ECT wire and threw a code. Oh well looks like i got to break out the drill.
Old Apr 30, 2002 | 11:32 PM
94GSRRacer2's Avatar
New User
where the hell is the thermostat on a 98 prelude SH?
anyone? i need to install a sender somewhere, since my current autometer one broke off in the stock hole.
boostedb20z
May 8, 2011 09:48 PM
powerdbygarrett
Oct 15, 2007 04:55 PM
boostincoupe
Aug 12, 2004 05:36 PM
monicle
May 27, 2003 10:41 AM
