Heat problem L@@K :P
Old Jun 28, 2006 | 07:38 PM
itr1244's Avatar
Default Heat problem L@@K :P
ok some of you guys know but i just finshed building the car and put evertyihg together.
i had alot of problems to go thru and it's still not over.
My IM feels as hot as the HOT coolant hose.
Heater only works for first 15-20 min of initial driving.
and the car heats up pretty fast. well alot faster than before at least. even tho i am running half sized rad.
and when my heater works. it's really hot and after the heater stops working it will not work again until i park the car for a while.
i bleeded the system 4-5 times already.
I went over the helms and checked if all the hoses are hooked up right.
and it's still samething.
is there any sensor that could be mixed up with anything?
T.I.A
Old Jun 28, 2006 | 10:34 PM
itr1244's Avatar
Default Re: Heat problem L@@K :P (itr1244)
mmm
Old Jun 29, 2006 | 06:29 AM
Doespike's Avatar
Is the engine temperature high? How about a bad thermostat or water pump? Depending on how long the motor was sitting since it was last run (before the build), those parts could be sticking or just dead. Good luck
Old Jun 29, 2006 | 07:04 AM
Larkin W.'s Avatar
Default Re: Heat problem L@@K :P (Doespike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doespike &raquo;</TD></TR><TR><TD CLASS="quote">Is the engine temperature high? How about a bad thermostat or water pump? Depending on how long the motor was sitting since it was last run (before the build), those parts could be sticking or just dead. Good luck </TD></TR></TABLE>
I don't think it would be the thermostat although it is possible. Honda thermostats tend to fail open causing the car to run cool
Old Jun 29, 2006 | 11:18 AM
itr1244's Avatar
Default Re: Heat problem L@@K :P (Larkin W.)
i installed new water pump as well
the project took me about 3 weeks or so
Old Jun 29, 2006 | 11:47 AM
RTW DC2R's Avatar
I think we need more info on your setup. Im assuming its boosted.
edit: nevermind
Modified by clip the apex at 8:56 AM 7/2/2006
Old Jun 29, 2006 | 11:53 AM
JjuuN R's Avatar
don't think it's boosted, could be wrong
Old Jun 29, 2006 | 10:12 PM
itr1244's Avatar
Default Re: (JUN.R)
n/a
Old Jul 1, 2006 | 04:27 AM
itr1244's Avatar
help me plz?
both top and bottom hose gets hot. doesnt that mean the thermostat's working?
Old Jul 2, 2006 | 04:02 AM
RTW DC2R's Avatar
not necessarily, but likely. are top and bottom the same temp (top should be slightly hotter)? are you overflowing any coolant? did you get new hoses and thermo when you put the motor back in? is the thermo installed properly? are you using a NON ITR head gasket (even if its OEM, B20 maybe?)? are you POSITIVE you routed all lines correctly?
Old Jul 2, 2006 | 04:10 AM
vtec.dc2's Avatar
sounds like coolant being blocked somewhere in/around heater core.. - otherwise your heat would be working 100%
Old Jul 2, 2006 | 01:57 PM
itr1244's Avatar
Default Re: Heat problem L@@K :P (clip the apex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clip the apex &raquo;</TD></TR><TR><TD CLASS="quote">not necessarily, but likely. are top and bottom the same temp (top should be slightly hotter)? are you overflowing any coolant? did you get new hoses and thermo when you put the motor back in? is the thermo installed properly? are you using a NON ITR head gasket (even if its OEM, B20 maybe?)? are you POSITIVE you routed all lines correctly? </TD></TR></TABLE>
yeah the top is slighty hotter
not over flowing any coolant,
old hose, oem itr head gasket , thermo never came off the thermostat housing
helldriver88
Jan 26, 2008 10:33 PM
itr1244
Jun 29, 2006 11:20 AM
md88hfcrx
10
Dec 20, 2005 01:08 PM
nut R.
Feb 22, 2005 08:53 PM
omar256hxc
19
Dec 20, 2004 12:46 PM
