H22 rebuild?
Old Jun 28, 2006 | 03:50 PM
bdpetska's Avatar
Default H22 rebuild?
I don't know about anyone else, but my lude is burning oil. I was wondering if this had to do with the aluminum cylinder walls. I'm planning a rebuild soon and hope to beef up the bottom end and valvetrain and maybe throw a few pounds of boost at it later (nothing to crazy). I'm hearing a lot about Mahle pistons. Whats the deal? Anyone one got any tips or parts that they recommend? Thanks.
Ben
(new to honda-tech)
Old Jun 28, 2006 | 04:03 PM
hu's Avatar
hu
Default Re: H22 rebuild? (bdpetska)
How many miles are on your current engine? Could be blow by (bad piston rings). Do you have an aftermarket oil pressure gauge? If so, make sure the sending unit isn't leaking.
Make sure you decide if you want to go NA or FI. You shouldn't use high compression pistons with a turbo build. Generally, people go with 9.0:1 compression ratio with pistons for turbo. NA can go 11.0:1 and higher.
Old Jul 18, 2006 | 02:46 PM
bdpetska's Avatar
Default Re: H22 rebuild? (hu)
i,ve got about 95k miles. i guess i could do compression and leak down test to make sure. do you happen to know how much boost the stock bottom end can handle with 9.0:1?
Old Jul 18, 2006 | 02:55 PM
pentaq's Avatar
it's not the compression matter. it's the matter how tough are your engine internals to deal with pressure and how your car is tuned.
Old Jul 18, 2006 | 03:07 PM
SKDRCR's Avatar
You can do a compression test on to see how your motor is doing.
Also, you'll have to sleeve your block if you plan on running forged pistons.
Old Jul 18, 2006 | 04:12 PM
hu's Avatar
hu
Default Re: H22 rebuild? (SKDRCR)
People have slapped on a turbo with a stock bottom end, but I don't think it lasts too long.
As stated above, you would need a sleeved block to run forged pistons. I know its a lot of $ (kind of) upfront but you will be happier in the long run.
MyEGisBad
Jan 19, 2011 10:12 AM
DulinDragons
Dec 3, 2009 09:05 PM
Jamarquis
Nov 12, 2007 06:35 PM
yosfynest11190
Jun 26, 2007 06:10 PM
