autometer tach...needle stays at top?? help
Old Apr 18, 2002 | 07:47 AM
speeddave's Avatar
Default autometer tach...needle stays at top?? help
hey guys wasn't sure where to post this so i thought i would try here. ok, i have a 5" autogage tach w/shiftlight, and i wired it according to directions... i put the green sending wire to the blue tach signal wire in dash, the red and white to the empty male plugs on the fusebox and i grounded it to a place where a stock wire was also grounded. my prob is this...everything works fine, but when i shut the car off the tach moves up past the 10thou rpm mark and stays there. when i start the car the needle falls back down. i moved the wires around to different sources but same result. i'm out of ideas, possibly bad ground?? this should be simple but maybe my brain is fried, ha ha. anyway thanks guys
Old Apr 18, 2002 | 07:58 AM
cvc96honda's Avatar
New User
Default Re: autometer tach...needle stays at top?? help (speeddave)
Mine does that too. I don't worry too much about it.
Old Apr 18, 2002 | 08:07 AM
speeddave's Avatar
Default Re: autometer tach...needle stays at top?? help (cvc96honda)
so yours flicks to the top when the key is turned off? and stays there, then returns back to normal when you start the car? where do you have you wires going? so you think its ok like that...it would be nice if it were to remain at the bottom. thanks for the help
Old Apr 18, 2002 | 08:09 AM
keithv's Avatar
i have a non-autometer tach and it doesn't do that at all. i am pretty sure i used the blue wire for the tach signal. i ran power to the fuse box, used a ground point near the radio. the illumination i hooked up to the cig ligther illumination.
that was all i did...
Old Apr 18, 2002 | 08:15 AM
speeddave's Avatar
Default Re: autometer tach...needle stays at top?? help (breaka_1_9)
weird...haha i dunno, hopefully soon i'll figure it out.
Old Apr 18, 2002 | 09:01 AM
cvc96honda's Avatar
New User
I hooked it up the same exact way that breaka_1_9 did. Mine doesn't always go to 10k, it will jump to any random RPM. The only thing that matters to me is that it works correctly while the car is running.
Kris
Old Apr 18, 2002 | 10:17 AM
88_SC_CRX_Si's Avatar
New User
Just drop them an email. They helped me within a day or two, when I was having trouble with my fuel pressure gauge....
Old Apr 19, 2002 | 07:00 AM
keithv's Avatar
Default Re: autometer tach...needle stays at top?? help (88_SC_CRX_Si)
the only thing i can think of is the tach signal's ground is different than the ground you used???
i am stretching a bit on this one.
Old Apr 19, 2002 | 01:59 PM
Jonathan_ED3's Avatar
dude..that is perfectly normal for it to 'sit' somewhere when you turn it off. the gauge is metered off air, and it's just something they do bro. most all autometer's and almost every other tach that's metered off air. mine sits on '3k' when i shut it off. if it's workin fine when it's 'on', then you have nothing to worry about....it even mentions this in the instructions that came with it. autometer-
doefat04
May 29, 2011 04:39 PM
slimjimdanny
Jan 31, 2007 07:35 PM
crx_gsr_vtec
Oct 24, 2006 10:04 AM
nkSi
Sep 30, 2001 09:47 AM
