will a stock b18c5 bottom end handle 9500 rpm's?
Old Apr 18, 2002 | 06:16 AM
Thrashin's Avatar
Default will a stock b18c5 bottom end handle 9500 rpm's?
ok im building a c5 for all motor. i have the skunk2 spec 2 cams and full valvetrain, all i want to know is will the c5 bottom end handle 9500 on a regular basis? thanks in advance
Old Apr 18, 2002 | 07:40 AM
SCsol's Avatar
Default Re: will a stock b18c5 bottom end handle 9500 rpm's? (jdmeg6)
PRM kills motor i would not push it that hard maybe 9000, do you have valve dual springs in the motor i have a C5 motor and i only spin it to 8600 RPM with cams and valve springs
Old Apr 18, 2002 | 07:49 AM
Thrashin's Avatar
Default Re: will a stock b18c5 bottom end handle 9500 rpm's? (lowsol)
i have the skunk2 dual valve springs, ti retainers, high comp. valves and spec 2 cams. the springs and retainers will hold 9500 no problem and the cams are suposed to make power all the way to 9500, so i would like to use that power. just wondering if the bottom end can keep up or if not what can i do to ensure safe reving.
Old Apr 18, 2002 | 11:46 AM
hybridreams's Avatar
Push it as high as you can go. 10,000 rpm. No need to use the clutch either. Power shift it. Yeah, go for it.
Old Apr 18, 2002 | 12:02 PM
Thrashin's Avatar
Default Re: will a stock b18c5 bottom end handle 9500 rpm's? (hybridreams)
is that how you ran your thirteen point eight? you are so gonna get schooled at the track little boy!
Old Apr 18, 2002 | 12:03 PM
ha ha
Old Apr 18, 2002 | 12:32 PM
RedTeg95's Avatar
I've done similar mods recently and called Skunk2 with the same question and they claimed my stock B18c1 bottom end should handle 9500 no problem. So I've reved it up to 9500 a few times now and it has held up no problem. It pulls the whole way. But I'm also curious what other opinions there are on this. I'm still looking into upgrading the connecting rods and pistons.
Old Apr 18, 2002 | 02:08 PM
badCRX's Avatar
New User
Default Re: will a stock b18c5 bottom end handle 9500 rpm's? (RedTeg95)
I've known someone to run a stock bottom end R and not have any problems to 9500 RPM's. It may ruin the motor faster than normal, but it will still last for quite a while I believe.
Old Apr 18, 2002 | 02:15 PM
AllMotorMadness's Avatar
it'll be fine.......
Old Apr 19, 2002 | 07:14 AM
Kataku2K3's Avatar
Default Re: will a stock b18c5 bottom end handle 9500 rpm's? (AllMotorMaddness)
It should be fine to spin the motor up there, your stock internals are plenty strong. The only thing you're goin to have to worry about up there is making power. Are you porting your head? I'm not really sure about the S2 cams how high will they make power. My friends CRVTEC motor had JUN3's in it and it started having a power drop off at around 8800 and those cams are ******* insane.
The only problem with them is a lot of people have had problems with them shatteriing.......
Old Apr 19, 2002 | 07:22 AM
SpooN Man's Avatar
Default Re: will a stock b18c5 bottom end handle 9500 rpm's? (JDMspecEG6)
Todasi had a stock b18c5 and he spun it up to 9500 with toda "b's" That thing sounded soo sweet, and it has yet to pop.
Old Apr 19, 2002 | 11:01 AM
NeXtLeVeL_TyPe_R's Avatar
It can handle it
Euro98ITR
Sep 15, 2008 02:47 PM
Boosted R
Feb 12, 2006 08:19 AM
jam05pr
Jun 6, 2005 09:31 AM
DOHCRX
19
Apr 5, 2003 07:00 AM
CRXSleeper
Sep 9, 2002 10:47 PM
