testing a power window motor?
Old Jun 27, 2006 | 09:02 PM
mr 636's Avatar
Default testing a power window motor?
sup guys. how do you check if the OEM power window motors are working? i bought the ek coupe window motors but i want to check them before i go ahead and install them. can i just hook up 12v power to the motors or do i have to wire it all up to the switches in order for it to move?
please help, thanks.
Old Jun 27, 2006 | 09:38 PM
.Kevin.'s Avatar
Default Re: testing a power window motor? (mr 636)
use a jumper wire from your fuse box or a drill battery ?
Old Jun 27, 2006 | 10:10 PM
mr 636's Avatar
yeah but i hooked it up to the car battery, a 12v source and it doesnt work. it moved a little when i tapped the wires on 3 D batteries.
Old Jun 28, 2006 | 06:05 PM
mr 636's Avatar
anyone?
Old Jun 30, 2006 | 07:39 PM
mr 636's Avatar
bump
Old Jun 30, 2006 | 09:25 PM
jdeemseerx's Avatar
use a power wire and a ground from the battery terminals try them both ways on the plug, ex: power, ground = up ground, power = down
Old Jul 26, 2006 | 03:47 PM
JDM*addiction's Avatar
Default Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">use a power wire and a ground from the battery terminals try them both ways on the plug, ex: power, ground = up ground, power = down</TD></TR></TABLE>
what he said.. i just basically jumped mine from the harness that connects to the motor.. i used a jump box and to pieces of wire and put one on the ground and one to power and touched it to the prong on the harnes and my window went up and i switched them and they went down
EKidd
Jun 1, 2007 09:32 PM
That Sob
Audio / Security / Video
Nov 1, 2005 01:51 PM
litterbox
Jan 17, 2005 03:07 PM
Muckman
21
Jul 9, 2004 08:51 AM
