Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 Si after lowering making noies
Old Jun 27, 2006 | 06:03 PM
pvt. snowball's Avatar
Default 06 Si after lowering making noies
ight yo i got my si lowerd lik a week ago but we got lazy n didnt take off the bump stop of course it was making noies soo just yestoday we cut of the bump stop but it was still making noies but only on the rear drivers side soo we double check everything but just cant find where is coming from my friend said its coming from the shock cuz he had read threads from 8thcivic dat pples been having noies coming from there stock shocks i dont kno wut to do because i dont wanna buy a new OEM shock n then its not really the problem soo any of u guys kno wuts going on or wut shud i do???
thanks for any tips and help
Old Jun 27, 2006 | 08:59 PM
BrandonSI06's Avatar
don't tell me you cut the stock springs!?!?!
Old Jun 27, 2006 | 09:43 PM
Default Re: (BrandonSI06)
nope i didnt cut the springs i got eibach sprotsline but the sounds not coming from springs
Old Jun 28, 2006 | 03:31 PM
06sik20z3's Avatar
did you possibly crack the strut mount it will squeak if cracked
Old Jun 28, 2006 | 05:44 PM
sickyute's Avatar
Default Re: (06sik20z3)
when the car is dropped too low it squeaks....not to sure of this....but the same happenned to me.
i dropped m car real low on tein SS...just above the wheel...no space really between wheel and fender but it wasn't tucked...that's with 18s.
i got some slight squeaking from the rear, especially the drivers side. i had the camber kits and everything istalled already.
i raised the car up a bit and it was there but not as much....raised it up a little to a finger gap between wheel and fender and the noise was gone.
i think if it's too low, it stresses a part or parts in the rear....causing the noise....as u can see the setup is the rear is not an everyday setup...
so it might just be the drop is too low....maybe someone else with sportlines can chime is...if they having the same issue...it's probably that.
Old Jun 28, 2006 | 10:19 PM
see it dosnt squeak its lik sumthing is hitting it sounds lik something thats metal soo u guys think is not the shocks???
Old Jun 30, 2006 | 03:58 PM
escocrx's Avatar
Default Re: (pvt. snowball)
mine does that because i ripped the **** out of the rubber damper that the spring sits on.
So now i get a spring noise whenever the car feels like shifting the spring around.
its awesome.
i ordered new ones. but havent got em yet. i also have Tein SS's like sickyute, but I have never got squeaks, just that spring noise, which I know it is. because i shoved a piece of cardboard in there for a test or 2,3 or more.
Old Oct 27, 2006 | 02:45 PM
japspecjohn's Avatar
Default Re: (escocrx)
i just dropped the front of my si on sportlines.... didnt get to the back yet got dark to fast lol...but any ways with fast jerks of the wheel back and forth I can here the spring make noise moving metal on metal ahh well guess i should of put the top rubber thing on durrr
Old Oct 27, 2006 | 05:53 PM
Fa1's Avatar
Fa1
Try to tighten the center nut on the top down more.
Old Oct 28, 2006 | 03:02 PM
Default Re: (Fa1)
damnn that was a reply after like 4 month since it was posted but thanks alot tho the funny thing is i dont even have the Si anymore ***** totaled!!! =[
Old Oct 28, 2006 | 03:34 PM
Default Re: (Fa1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fa1 &raquo;</TD></TR><TR><TD CLASS="quote">Try to tighten the center nut on the top down more.</TD></TR></TABLE>
can you do this while they are in the car?
lando griffin
Suspension & Brakes
Jan 19, 2008 02:06 AM
fishin9975
Oct 24, 2004 06:31 AM
mjrage
Nov 11, 2003 10:12 AM
LB CRX
Nov 9, 2003 02:42 AM
EVIL Hx Coupe
Sep 3, 2002 12:30 PM
