help needed guys on set up
hi im colleting my new car at the weekend its a 00 vti hatch b16a2 turbo.
this is the spec;
CHROMALLOY ULTRA LIGHTWEIGHT FLYWHEEL
550 CC INJECTORS
BLITZ AIRFILTER
PEAKBOOST STAINLESS STEEL EQUAL LENGHT EXHAUST MANIFOLD MADE OF 321 8 GAUGE STAINLESS STEEL
GARRET T3/TO4E TURBOCHARGER
TIAL 38MM EXTERNAL WASTEGATE AND SCREAMER PIPE
PEAKBOOST GARRET CORE 24X6X3.5 INTERCOOLER (2.5" INLET AND OUTLET)
TIAL BLOW OFF VALVE
TIG WELDED 2.5" CHARGE PIPING
3 INCH DOWNPIPE
FULL 2.5IN CUSTOM BUILT STAINLESS STEEL EXHAUST SYSTEM WITH CAT FOR MOT
UBERDATA CHIPPED ECU
WALBRO UP RATED FUEL PUMP
ACT UPRATED CLUTCH PLATE AND PRESSURE PLATE
ok lads this is the way ill be getting the car but the person im buying the car off also threw some more goodies in also and i was wondering wat ye thought he said this is all ii would need to get 360 at 1 bar safely need some advice from the experts heres the list yet to be fitted;
1.8 integra block b18c been overbored .25
wiseco pistons to match and eagle rods
eagle block guard
skunk 2 adjustable front camber arms and rear omni adjustable camber arms
please lads need advice on this and can anyone think of anything else that i should get myself before i install all of the above??
cheers lads
this is the spec;
550 CC INJECTORS
BLITZ AIRFILTER
TIAL BLOW OFF VALVE
3 INCH DOWNPIPE
eagle block guard
cheers lads
AlphaQup
Oct 10, 2005 10:00 PM
Hoodwinked
Apr 5, 2005 02:48 AM
