Omnipower Test Pipe
Old Jun 27, 2006 | 03:46 AM
Spo0NFed E M 1's Avatar
Default Omnipower Test Pipe
Calling all peeps who own em'...did you have to clamp yours where the 3 pieces extend? I have it running w/o em and cant tell whether or not its the collector and front of test pipe or the actual test pipe leaking. Ive already tried pluggin the end of the exhaust for pressure but still nothin. Anyone?
I am running it with a Megan 4-1 2.5'' Header and some crappy donut gasket from Advance Auto...
Thanks
Old Jun 27, 2006 | 03:59 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Omnipower Test Pipe (All MTR xsI)
so, you have an exhaust leak? usually you can just look, as the area that is leaking will have black soot around it. you can try running the car on jackstands and putting your hand near (not ON) the area you think is leaking and you will feel the exhaust pulsing onto your hand.
Old Jun 27, 2006 | 04:00 AM
SovXietday's Avatar
Most people don't clamp the omni test pipes, your exhaust leak is probably from the donut.
My friend actually tacked a few small welds to keep his pieces from shifting, but carbon build up is supposed to block any kind of leaks on the test pipes.
Mine will be going on shortly so I'll let you know, just waiting for my Kami header which comes today.
Old Jun 27, 2006 | 07:14 AM
JDM_teh_WIN!!'s Avatar
Default Re: Omnipower Test Pipe (SovXietday)
YEah clamp it. I used 2 2.5 or 3in exhaust clamps and it works real well. I have a JDM header, JDM Test pipe, and ITR B-pipe all OEM hardware. This is on a Civic coupe. If you plan on having the same exhaust for a while you can get it welded.
PS: Just dont clamp it down extra tight and crush the test pipe, just make it snug and it'll stay together. It will leak a little but nothing worth worrying about. I get complements on how good my exhaust sounds all the time.
Old Jun 27, 2006 | 08:53 AM
JDM Pheen's Avatar
you i seen you racing the other night spankin mad people i thought your car was turbo the way you beat that turbo vr4.. well as far as the test pipe goes, i have old exhaust stuff you can cut flanges off and weld them up and you can bolt and unbolt your test pipe let me kno if you wanna cut **** up... ohh and your going to need a #2 pencil fpr your pipe well you need it for every test lol
Old Jun 28, 2006 | 03:49 AM
haha... The test pipe has 3 pieces to it. 2 tucked into a center piece and i think its leaking from there. Omniman told me that It should take about 2-300 miles before the carbon seals itself shut. Any truth to this?
Old Jun 28, 2006 | 08:48 AM
bump before I try to clamp/weld it...
Old Jun 29, 2006 | 07:22 AM
clamped it yesterday, see how it turns out.....
Old Jul 1, 2006 | 08:21 AM
bump
nicolaselias
Jul 1, 2010 12:48 PM
rexman2002
Jun 12, 2009 02:20 PM
jdm j
Honda S2000
12
Oct 6, 2007 07:42 AM
EGhatch33
May 1, 2006 09:37 PM
HX_Guy
Sep 8, 2001 09:59 AM
