material and thickness turbo manifold vs N/A manifold
Old Jun 27, 2006 | 12:33 AM
hondaapi's Avatar
Default material and thickness of turbo manifold vs N/A manifold
I know that most people use thick material (mostly 304 or 321) for theire turbomanifolds.
But what do you suggest for N/Amanifolds. I think they can be made of thinner materials. What thickness do you prefer (if possible in inch, so that I can calculate it to our mm-system) or suggest? Is 304 a good choise?
Thanks
Old Jun 27, 2006 | 06:44 AM
k24em2's Avatar
Default Re: material and thickness of turbo manifold vs N/A manifold (hondaapi)
304 is a common material for both because of its strength and is fairly inexpensive. 16 gauge seems to be the most common available (1.61mm) but 18 gauge (1.31mm) is probably a better choice for a normally aspirated header.
Old Jun 27, 2006 | 07:06 AM
hondaapi's Avatar
Default Re: material and thickness of turbo manifold vs N/A manifold (k24em2)
Thanks. That´s what I wanted to know.
Can you explain what gauges means? Or how is is calculated in mm.
I often read gauges but I do not know how to calculte it into our mm-system.
Old Jun 27, 2006 | 07:56 AM
Ekasey's Avatar
We use either 304 Stainless in .065" or .049 sometimes .035 (16g 18g 20g) G= gage
or 321 in a .049" or .035" ( 18g and 20g) Thickness
or Inconel 625 in .035 and .028 (20 and 22g)
Old Jun 29, 2006 | 09:56 AM
Enzo-Racing's Avatar
Default Re: material and thickness of turbo manifold vs N/A manifold (Ekasey)
16 ga is usually enough for turbo when built properly...
95IntegraGSRAZ
Welding / Fabrication
Jun 16, 2006 03:25 PM
allblackgsrt
Dec 19, 2005 06:59 AM
.dave
10
Dec 10, 2004 07:49 PM
Full-Race Geoff
Apr 28, 2002 07:33 AM
Crxlsturbo
Aug 5, 2001 01:05 PM
