wiring vtec on Jdm b16a swap..
Old Jun 26, 2006 | 09:38 PM
1baddc5's Avatar
Default wiring vtec on Jdm b16a swap..
ok fellas well my buddy and i just swapped his car last week and the map sensor wasnt on the JDM motor which he purchased from password jdm and so we took the D series harness off the d15 motor and put it on there and i was wondering what it took to wire the vtec on the B16a or should we of used the B series harness and just wired in the map sensor cause he drove it without a map sensor and burnt a tank of gas in 125 miles so we changed the harness just to have the map sensor and i know theres a way to do this just lemme know what to do or something thanks alot and the throttle cable bracket is not working with the throttle cable from the 94 civic what can we do about that also any help would be greatly appreciated people thanks
Old Jun 26, 2006 | 10:45 PM
fmrprojects's Avatar
Default Re: wiring vtec on Jdm b16a swap.. (1baddc5)
you can just plug in a map sensor and get a 1/4 in vacum line and run it from the nipple of the map sensop to the top nipple of the throttle body. what yr is the car? if you are trying to wire the vtec, the solenoid is A6 and the vtec oil pressure sensor is D6
Old Jun 27, 2006 | 03:53 AM
1baddc5's Avatar
its a 94 what do think we should do d series harness or b series cause the b series is completely backwards from the d series cause it is jdm and you have to stretch things to make them work ya know.........
Old Jun 27, 2006 | 07:16 AM
Slopoke's Avatar
I would just use the D series harness and add the wires for vtec solenoid, vtec oil pressure swtich, and knock sensor.
Old Jun 27, 2006 | 08:07 AM
1baddc5's Avatar
Default Re: (Slopoke)
ok so where do they wire too under the dash a wire diagram would be so much help or something fellas if you got it or know thanks
Old Jun 27, 2006 | 08:12 AM
plz turn off trial user's Avatar
Default Re: (1baddc5)
125 is what i get in my civic even tho it runs rich, and backfires whenever how do i fix that lol, o btw its a d16z6 with jdm zc head
Old Jun 27, 2006 | 02:04 PM
1baddc5's Avatar
any help fellas???
Old Jun 27, 2006 | 02:15 PM
1baddc5's Avatar
any help on how to wire up vtec and where it goes ???
Old Jun 27, 2006 | 05:17 PM
1baddc5's Avatar
nevermind guys got it done thanks for your input ........
Old Jun 27, 2006 | 09:08 PM
elaborate
Old Jun 27, 2006 | 09:11 PM
1baddc5's Avatar
Default Re: (civicfast)
i found a wiring harness on the internet for the b16a into the EG here i found it on here
https://honda-tech.com/zerothread?id=1004852
that should help you out alot i dont basically the same thing and it worked great...
LS94tegra
Oct 13, 2008 05:17 PM
0ldsk00lef
Aug 22, 2007 08:55 PM
Brian Hinson
13
Jun 24, 2006 04:05 PM
pnltnc
May 11, 2004 03:43 PM
