new clutch, problems
Old Jun 26, 2006 | 04:39 PM
got2's Avatar
Default new clutch, problems
I just had the clutch on my gsr replaced by the local schmuck and now the clutch pedal has vibration near the top of the release. I told him that it feels like the pressure plate wasn't centered properly on the flywheel or that the flywheel wasn't resurfaced properly. He tells me that I don't know **** about cars and it's because of the CV boots that I didn't want him to replace. Now, assuming my cv joints were shot to **** and my axle was broken, would the clutch pedal vibrate when the car isn't moving if there wasn't something else wrong??? I think not! Opinions?
thanks as always
Old Jun 26, 2006 | 05:47 PM
teddy_dc2's Avatar
what kinda clutch? 3 months i threw in my clutchmaster stg 3 with flywheel and it vibrates too, doesn't affect performance but annoying. i think this is causing my throw out bearing to ware out, i don't know if it's normal for new clutch kits (refering to t.o.b.) to ware out fast, it getting louder.
Old Jun 26, 2006 | 05:48 PM
teddy_dc2's Avatar
3 months ago i ment.
Old Jun 26, 2006 | 06:04 PM
akstunt600's Avatar
did he replace the pilot bearing????
for both of you guys actually??
there should be absolutely no vibration throught the pedal.
the pilot bearing is what centers the input shaft in the transmission, your gears wont live very long if this was left out, or the old one was in ver bad condition. just fyi, i have seen alot of idiots leave them out completely
Old Jun 26, 2006 | 06:19 PM
teddy_dc2's Avatar
my pilot bearing came already pressed in f.w., i did my buddy's exedy clutch and flywheel for a gsr'd ek and his doesn't vibrate. i had to pound his pilot bearing in. i don't know why that is..
Old Jun 26, 2006 | 06:21 PM
akstunt600's Avatar
mainshaft bearings in the tranny or your feeling other vibrations, mounts, etc...
Old Jun 26, 2006 | 06:23 PM
teddy_dc2's Avatar
actually after i broke in my clutch, i had to shift a gear lower just to get into 3rd or fifth, example: going to fifth i would have to clutch, put in fourth and the to fifth, or clutch and throw it in second before i go into third. if i just go straight into 3rd or fifth, i would have to force it in.
Old Jun 26, 2006 | 06:25 PM
teddy_dc2's Avatar
it is the clutch alright, i makes a squeaking belt noise when pedal is free and vibrates, noise goes away when slightly pressed.
Old Jun 26, 2006 | 06:55 PM
akstunt600's Avatar
deffinately main shaft, diff bearings or throwout, but im guessing you replaced that
Old Jun 26, 2006 | 07:27 PM
teddy_dc2's Avatar
i replaced the clutch, pressure plate, pilot bearing, flywheel and throwout bearing. it does feel like a slip once in a while under heavy abuse.
k_lude
Oct 31, 2006 11:27 AM
Y2ksi
Mar 16, 2005 03:55 PM
NOSED_CRX_VTEC
Oct 7, 2004 11:20 AM
vishyncsu
Oct 7, 2004 10:38 AM
animated_life
May 5, 2003 02:53 PM
