fried ground!? ****HELP****
Old Jun 26, 2006 | 02:51 PM
.kyle's Avatar
Default fried ground!? ****HELP****
well, i threw a cel. . when i went to check it i took the plug thing out of the green rubber case. . then i was an idiot and tried to start my car (please dont ask me why hah ) but i got a sputter then smoke came out of under my hood. when i popped it. . all my grounds were smoking. . and now have black spots all over the ends. . . now it doesnt turn over . it just clicks, and so i need new ground wires but do i need to replace my starter or alternator? thanks in advance for any help!!
Old Jun 26, 2006 | 02:52 PM
Slamaccord's Avatar
Default Re: fried ground!? ****HELP**** (IWantATurbo)
Start with he ground wires. Your starter isn't engaging do to the bad grounds.
Old Jun 26, 2006 | 03:13 PM
.kyle's Avatar
Default Re: fried ground!? ****HELP**** (Slamaccord)
thanks bump! anything else? would it only be the ground to the battery? the main ground? or all of them?
Old Jun 26, 2006 | 03:15 PM
Slamaccord's Avatar
I'm still confused why you fried the grounds. Can anyone else elaborate on this
situation please.
Old Jun 27, 2006 | 09:43 AM
.kyle's Avatar
bump more help
Old Jun 27, 2006 | 09:46 AM
the jdmchop's Avatar
can you explain why the grounds fried?
you can loop the ground for the CEL plug and still have the car running so i dont know what you did?
check all the fuses first
did you use the 2 wire brown plug to check the codes?
Old Jun 27, 2006 | 09:50 AM
.kyle's Avatar
Default Re: fried ground!? ****HELP**** (anti-lag aka JDMCHOP)
yeah i used the two wire brown plug, . . i dont know what happened! i need to check the fuses though.. didnt do that.
Old Jun 27, 2006 | 10:31 AM
EE_Chris's Avatar
Umm...the 2-pin connector in that green rubber plug can be shorted while the car is started. It's how you set the timing anyway. Plus, one of those wires is actually a ground.
So, if all you did was jump the service connector and tried starting your car and your grounds fried, then you're leaving a piece of the story out.
Did you have ALL of the grounds connected initially? Battery-chassis, tranny-chassis, valve cover (power steering pump)-chassis and the thermostat?
Old Jun 27, 2006 | 10:59 AM
.kyle's Avatar
Default Re: fried ground!? ****HELP**** (EE_Chris)
im really not. . but a couple days before that. . i was trying to connect my ground to the battery and it kept sparking but i couldnt figure out why. . it stopped after me moving all my tools off my fenders. .
but yeah thats exactly what i did. . jumped it with the 2-pin open. .
help me. . what can i do to fix it
Old Jun 27, 2006 | 12:17 PM
EE_Chris's Avatar
Moving tools off of the fender would imply some work was being done. What were you doing?
Simply checking for ECU codes will not cause the problem you have. I have a stock 99 Civic hatch and when re-connecting the battery terminal, it does a quick spark too.
Is your car stock? What's the setup?
Old Jun 27, 2006 | 02:50 PM
.kyle's Avatar
i just finished up putting my turbo on and putting in a clutch. . . i have a t3 turbo'd d16z6. . the z6 is stock. . so what do you think the problem is . . did i forget about my tranny ground. . ? thats what im thinking was touching something when i tried starting it. . and it has nothing to do with me having the 2 pin plug out of the rubber holder. .? am i right? or maybe its the fuses?
Old Jun 27, 2006 | 03:10 PM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Did you have ALL of the grounds connected initially? Battery-chassis, tranny-chassis, valve cover (power steering pump)-chassis and the thermostat?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWantATurbo &raquo;</TD></TR><TR><TD CLASS="quote">did i forget about my tranny ground. . ?</TD></TR></TABLE>
Whatcha asking me for? Check'em.
Yes, the 2-pin connector has nothing to do with it.
BobbyRodriguez
Nov 16, 2011 05:15 AM
ruckussss
Jul 23, 2005 03:58 PM
ChickenMan
Oct 15, 2004 07:11 AM
1strdtko
Apr 6, 2003 11:02 PM
vtec69
Jan 17, 2003 03:30 PM
