rpm needle goin stupid dumb and hyphy after 3k??? please help
Old Jun 26, 2006 | 02:01 PM
98B18C1's Avatar
Default rpm needle goin stupid dumb and hyphy after 3k??? please help
this has been happening for a good while now...every morning after i start the car, it idles fine but wen i drive it the rpm needle starts jumping around like crazy. Once i decelerate it goes down normally but wen im on the gas it jumps every single time and now i cant tell wen im going to hit redline...please help guys im clueless...and after a long while driving the car it is fine but after 3k it goes crazy again..it flickers even at a constant speed...
Old Jun 26, 2006 | 02:04 PM
DC2 Mang's Avatar
Default Re: rpm needle goin stupid dumb and hyphy after 3k??? please help (98B18C1)
sounds like and ignition problem
is the tach just jumping or is your motor actually bogging and skipping around?
Old Jun 26, 2006 | 02:18 PM
98B18C1's Avatar
the tach is just jumping motor runs great
Old Jun 26, 2006 | 02:33 PM
DC2 Mang's Avatar
Default Re: (98B18C1)
the film on the back is probably fucked up, or there is a short in your wiring, if you have a friend with a DC ask them to borrow their cluster to see if it still does the same in your car
Old Jun 26, 2006 | 10:41 PM
98B18C1's Avatar
imma try to hook up a tach and see wat happens
Old Jun 26, 2006 | 10:48 PM
Takumi Fujiwara's Avatar
I had the problem before, and it was the ignition module. Many members actually...
Old Jun 26, 2006 | 11:04 PM
98B18C1's Avatar
ignition module? is that in the dizzy? the little box on the side?
Old Jun 26, 2006 | 11:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">ignition module? is that in the dizzy? the little box on the side?</TD></TR></TABLE>
Yes, inside the dizzy, it's rectangular or square depending on what year/model dizzy you have.
Old Jun 26, 2006 | 11:20 PM
Default Re: (Takumi Fujiwara)
it could be a bad ground too though...
Old Jun 27, 2006 | 12:11 AM
98B18C1's Avatar
where would the ground be located at?
Old Jun 27, 2006 | 12:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">where would the ground be located at?</TD></TR></TABLE>
I would try to locate a spare ignitor (OEM name - Ignition Module) and swap it out and see if that fixes your problem.
Next I would use dielectric grease on all the connections inside the dizzy.
Finding a loose ground can be painful.
Old Jun 27, 2006 | 06:11 AM
bshshondaman06's Avatar
but he says the engine runs fine. maybe it is a problem with the tach.
Integra21
Dec 26, 2006 08:39 PM
boostedteg15
Aug 4, 2006 06:55 PM
sgtroseberry
Jul 1, 2006 06:11 PM
sc300turbo
10
Feb 4, 2005 12:13 PM
cyberjunkie
Aug 5, 2004 04:00 PM
