Window Help
Old Jun 26, 2006 | 11:17 AM
unraveled's Avatar
Default Window Help
In my 99 ek the window doesnt go all the way up it seem as if the motor cant put the window all hte way up anymore it makes a clak sound at the top. Does anyone know if a 96-98 motor would fit my 99 civic ex...?
Old Jun 26, 2006 | 11:25 AM
Rock Meathammer's Avatar
Default Re: Window Help (unraveled)
As long as it's the same number of doors it will fit. I don't think thats what your problem is though. It sounds to me that the tracks are pinched at the tops.
Old Jun 26, 2006 | 11:36 AM
unraveled's Avatar
Default Re: Window Help (B20 EJ6)
ok at the top i open the door to look everything is fine it look like it that sprocket looking thing it just goes clak clak clak when its at the top.... i moved the tracks apart and tightened them
Old Jun 26, 2006 | 11:40 AM
Is the gear on the window motor missing teeth? I suggest you take it all apart and inspect. That will be the best way to find whats failing.
Old Jun 26, 2006 | 11:42 AM
unraveled's Avatar
how do you get to it since its behind all te metal oh and thanks for your help man
Old Jun 26, 2006 | 11:54 AM
Default Re: (unraveled)
Roll the window down half way. Take out the two 10mm bolts in the window tabs. Pull the window out at an angle. Place it somewhere safe. Take the rest of the 10mm bolts that hold the regulator out.(4-6 bolts) Fold the regulator inside the door to make it easier for extraction. Take out regulator. Inspect it. You really need to take the tracks completely out to find any bends in the metal. Once you find something irregular, keep note for possible replacement. I've never replaced the tracks, I just bend them back. I do replace a lot of regulators at work though.
Old Jun 26, 2006 | 07:05 PM
unraveled's Avatar
Default Re: (B20 EJ6)
the regulator being the motor of the window...? has this happened before to you....? cause yea it does look like the motors ok cause it going all the way up intil i gets to top were the seal is it doesnt seal and it makes that noise... rain got in my car now it smeel funny :/
Old Jun 27, 2006 | 06:41 AM
unraveled's Avatar
bump
Old Jun 27, 2006 | 06:56 AM
jdm_bones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">Is the gear on the window motor missing teeth? I suggest you take it all apart and inspect. That will be the best way to find whats failing.</TD></TR></TABLE>
I also think is this^^^^^
Old Jun 27, 2006 | 07:04 AM
eg8civic93's Avatar
Change your regulator.
Old Jun 27, 2006 | 07:32 AM
unraveled's Avatar
Default Re: (eg8civic93)
what the regulator and can i use one from a 96-98 civic its powered window mine is to
Old Jun 27, 2006 | 07:36 AM
the regulator is the thing that the motor is bolted to. Usually the regulator and motor are replaced as one item. Yes a 96-98 will fit as long as it has the same number of doors. ex: a 4 door regulator will not fit a 2/3 door because they are different sizes. From 96-00 the doors are identical. Its still the same chasis.
Old Jun 28, 2006 | 08:01 AM
unraveled's Avatar
thanks
Old Jun 28, 2006 | 01:26 PM
krisjk2's Avatar
my car does the same thing and there are no missing gears. it is very annoying. im guessing change your regulator to see if that helps cause i don't think it is teeth on the gear. im to lazy to fix mine for myself
gqskrub
Apr 19, 2016 06:43 PM
acc0rdf22
Oct 8, 2009 12:17 PM
sii.
Aug 10, 2009 09:00 PM
TravisCadello
Apr 15, 2009 07:57 PM
tenkenaid
Oct 13, 2008 06:27 PM
