Benson Sleeved block leaking water
Old Jun 26, 2006 | 02:52 AM
YashiMotors's Avatar
Default Benson Sleeved block leaking water
Hi there,
We have a Benson Sleeved B16 block 85mm open deck style. And the block is leaking water in the cumbustion chamber so its smoking white.
We have changed the head gasket from a Cometic into a Honda OEM, as well as we machined the head surface but once again it's leaking. Head is oki. Everything is double checked and oki.
Before we installed the bottom end together we machined the block surface as we allways do on blocks we get.
But we have heard that you are not suppost to machine these blocks, cuz the sleeves must be 0,1mm above the surface on the side of the block? Is this right?
Old Jun 26, 2006 | 04:41 AM
methos713's Avatar
Default Re: Benson Sleeved block leaking water (YashiMotors)
you could pm EARL about it. He's the guy who does Benson sleeve blocks.
Old Jun 26, 2006 | 04:43 AM
hondaapi's Avatar
I´m not exactly sure how the Bensons blocks are build but on the ERLPerformance blocks you need!!! this little step. That´s called the step deck.The sleeves will sink a little when you intall the head and through the step deck you make sure them not to leak. Machining the block to be flat seemed to be a very bad idea.
Old Jun 26, 2006 | 04:50 AM
SPOOLINmatt's Avatar
Default Re: Benson Sleeved block leaking water (hondaapi)
yeah, sleeves should be about 3 thousandths above the outer deck. its not required though.
Old Jun 26, 2006 | 05:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaapi &raquo;</TD></TR><TR><TD CLASS="quote">I´m not exactly sure how the Bensons blocks are build but on the ERLPerformance blocks you need!!! this little step. That´s called the step deck.The sleeves will sink a little when you intall the head and through the step deck you make sure them not to leak. Machining the block to be flat seemed to be a very bad idea.</TD></TR></TABLE>
Is it anyway to fix this? O rings ? Maybe machine down the surface around the block.
Is this the same with sleeved blocks from Golden Eagle, we have dpne the same with one of the blocks from them but that one didn't have this "step deck". We havn't run that car yett.
In that case this is really stupid, cuz they should have written a warning text together with the papers.
Modified by YashiMotors at 2:49 PM 6/26/2006
Modified by YashiMotors at 2:50 PM 6/26/2006
Modified by YashiMotors at 2:53 PM 6/26/2006
Old Jun 26, 2006 | 05:51 AM
purpleh22's Avatar
When mine was sleeved (H22 closed deck) the block was surfaced afterwards and the head was done also. No probs. running @16 lbs.
Old Jun 26, 2006 | 11:47 AM
earl's Avatar
The block should seal fine as a flat deck but it must be a very smooth finish. Does the block have the Benson logo CnC'd into it or is it an earlier block? You should never surface a block unless it needs it, however.
racerx510
29
Feb 4, 2013 05:44 AM
chrisdiz
Nov 28, 2010 08:22 PM
panda_eh2
Dec 27, 2007 11:32 PM
YashiMotors
18
Jun 29, 2006 05:48 PM
Turbo Lude SH
Nov 22, 2002 01:52 PM
