i need help on a light, why does the "Anti Lock" Light come on?
its yellow, and only when i drive it turns on. for a 1991 integra GS.
anything else need to be known? reply or pm =/ THANKKZZ
YOUR BRAKES ARE GOOD JUST YOUR ABS SYSTEM IS BAB. LIKE A ABS SENSOR ARE VERY COMMON ON THESE CARS. ALSO COULD BE THE ACCUMALATOR OR PUMP GOING BAD ALSO. CHECK TO SEE IF THEIRS BRKE FLUID IN THE ABS UNIT IF NOT POUR SOME IN. CHECK THE CODE. ON A COUPE THE ACCESS COVER IS ON THE RIGHT SIDE OF THE CAR BY THE BACK SIT/ON THE PANEL AND ON A 4 DOOR ITS LOCATED IN THE TRUNK RIGHT SIDE NEAR HINGE. HAVE SOME ON TURN THE IGNITION SWITCH TO THE ON BUT DONT START THE CAR AND COUNT THE NUMBER OF FLASHES.FLASHES ARE COUNTED BY A 10 SECOND PAUSE THEN FLASHES CERTIN TIMES. EXAMPLE CODE 4-2
10 SECOUND PAUSE THE 4 FLASHES THEN 1 SECOUND PAUSE THEN 2 FLASHES. IF CODE 1 PAUSE THEN 1 FLASH THEN A LONG PAUSE. AND ECT..... THEN CODE IS READ FIX THE PROBLEM THE REMOVE THE ABS FUSE #2 TO CLEAR CODES. IF FOUND CODE AND DONT KNOW WHAT IT IS EMAIL ME FOR THE CODE.
Check the Integra forum FAQ thread for a link on how to pull the ABS codes. They will tell you what is causing the light.
also, check your fuses.
my abs light was on for a while because my fuse for my rear defroster was blown, I didnt know what it was, becuase I never blew it, then I decided to go look at my fuses, and that solved the problem.
B_Something
Suspension & Brakes
Jan 13, 2009 07:01 AM
gurlracer_camille
Dec 10, 2006 10:56 PM
