ABS light
Old Oct 28, 2003 | 07:03 PM
92 GSR's Avatar
Default ABS light
I did a search so please dont rag on me.
My abs light comes on about 1min after i start driving the car. So i do a search and see that most likely it's my e-brake sensor. I take off the panel to see the ABS unit so see if what code it's throwing. To my surprise it's not throwing any codes. So here are my questions....
1. When checking for a code should......
a) Run the car till the light comes on pull over and check to see if the
light is flasshing?
b) turn the keys but don't start the engine and then check for code
c) none of the above
2. I believe my rear drivers side caliper has seized. When i move the car
slowly the brake make a terrible squeeking noise. Could this cause the
ABS light to come on.
3. Can you unseize a caliper?
thanks for any help,
Neil
Old Oct 28, 2003 | 07:09 PM
SubieDude's Avatar
Default Re: ABS light (92 GSR)
its most likely that seized caliper....replace that and reset your ecu
Old Oct 28, 2003 | 07:37 PM
92 GSR's Avatar
Default Re: ABS light (WhiteS2)
do i need to buy a new caliper
Old Oct 28, 2003 | 10:51 PM
92 GSR's Avatar
anyone
Old Oct 28, 2003 | 11:18 PM
sinfulDB1's Avatar
mine comes on once in awhile... if i turn my car and its on . . . i turn off the car and restart it it goes away . . . anyone know what that is??
Old Oct 29, 2003 | 12:37 AM
iH8RICERZ's Avatar
Default Re: ABS light (ikendc2)
mine comes on after 30 seconds of driving and stays on...........i just checked the code just like as you would check an engine code. Mine ended up being my front passenger wheel speed sensor. Try pulling to see what code our abs is throwing. Your ecu stores that information even when you turn off your car.......
Old Oct 29, 2003 | 12:53 AM
King_j's Avatar
correct me if im wrong
i thought the abs system was only hooked up to the front calipers. therefore, if you had rear caliper problems, it would have nothing to do with abs.
is your rear rotor warped? are you sure the caliper is siezed?
Old Oct 29, 2003 | 04:49 AM
WhatThaFrig's Avatar
Default Re: ABS light (King_j)
My light came on after i lowered my Teg. I've been told it's the ABS sensor but I'm too lazy to check the codes.
Old Oct 29, 2003 | 10:35 AM
92 GSR's Avatar
Default Re: ABS light (WhatThaFrig)
can someone go over how you check the codes just to make sure i was doing it right. Also is there any way to tell if the rotor is warped or if it's the caliper?
thanks,
Neil
Old Oct 29, 2003 | 11:12 AM
player2z's Avatar
I have the same problem, my abs light is on since i bought the car..... i dont know what to do? I can hear my abs calibrating... please help us
Old Oct 29, 2003 | 04:33 PM
deepgreengsr's Avatar
Default Re: ABS light (player2z)
is their fluid in the abs bottle?
Old Oct 29, 2003 | 04:56 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhatThaFrig &raquo;</TD></TR><TR><TD CLASS="quote">My light came on after i lowered my Teg. I've been told it's the ABS sensor but I'm too lazy to check the codes.</TD></TR></TABLE>
did u lower the car yourself? i know when i lowered mine i had to take all the abs sensors out and put em back, what a bitch
Old Oct 29, 2003 | 07:41 PM
naturelovindc2's Avatar
Undo the 10mm bolts that hold the sensors on and clean them. Also wipe the notched part of the axle that the sensor reads. When I yanked my motor a few weeks back I noticed they were all caked up w/dirt, grunge, etc.
Old Oct 29, 2003 | 08:38 PM
Komsomol's Avatar
Default Re: ABS light (naturelovindc2)
Mine comes on with all the other pretty lights when I first start the car.
Then they all go off
Agent Daimon
Nov 8, 2010 12:03 PM
accordhybrid
Jun 2, 2003 02:37 PM
andrewasf77
Nov 26, 2002 09:19 AM
Havokgsr
Oct 1, 2002 03:25 PM
