Back Pressure?
i think it all depends... not havin any back pressure then i think u will loose power..i think u want a lil back pressure..but not to much..but im no expert.
you need a certain balance, hondas burn valves with minimal to zero backpressure, the exhaust flows too easily over the edge of the valve superheating it and causing it to disintegrate slowly. D series stock shouldent go beyond 2.25" piping, all motor builds can go 2.50, turbo builds are diffrent, the turbine causes backpressure, so you can run a 4" exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">you need a certain balance, hondas burn valves with minimal to zero backpressure, the exhaust flows too easily over the edge of the valve superheating it and causing it to disintegrate slowly. D series stock shouldent go beyond 2.25" piping, all motor builds can go 2.50, turbo builds are diffrent, the turbine causes backpressure, so you can run a 4" exhaust</TD></TR></TABLE>
says he who is about to buy my 2.5" muffler!!!!! HYPOCRITE, lol, just messin around
. I dont even know what you got, built or not.
xkwzt21
Feb 28, 2005 07:26 AM
