creative ideals?
Old Jun 25, 2006 | 04:51 PM
0618turbocivic's Avatar
Default creative ideals?
hey just thought see what people came up with for engine mods, setups, interior and exterior ideals etc ... pics be great or details
Old Jun 26, 2006 | 03:51 PM
Mr.E.G.'s Avatar
Default Re: creative ideals? (0618turbocivic)
maybe you should try the new cerMamic headers.
Old Jun 26, 2006 | 08:22 PM
Default Re: creative ideals? (Mr.E.G.)
haha nope im not newb with cars, i was seeing what people have different such as ic piping setup, interior.swaps etc, i have all my gauges in the passenger dash so doesnt look like i have things done to my car from around it other than hfmic
Old Jun 26, 2006 | 10:20 PM
Mr.E.G.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0618turbocivic &raquo;</TD></TR><TR><TD CLASS="quote">haha nope im not newb with cars, i was seeing what people have different such as ic piping setup, interior.swaps etc, i have all my gauges in the passenger dash so doesnt look like i have things done to my car from around it other than hfmic</TD></TR></TABLE>
oh i wasnt making fun of you. i was making fun of the guy who made the post about the cermamic. i was just trying to be funny but i guess i just fucked up your thread instead. sorry.
here is a suggestion. i once made a gated shifter for my civic. start by removing the shifter boot. measure the distance that the shift lever travels front to back from first gear to second, at the base where the shifter meets the floor molding. then measure the diameter of the shift lever at that point is well. so now you should have a couple of dimensions:
the distance from the most forward postion of first gear to the most rearward postion of second gear.
and the width of the shift lever itself.
so lets say the throw measures 3 inches and the width of the shift lever is .5 inches
take some thin plastic sheeting or plexi glass and cut this shape out of it with a dremel tool:
this shape will be the same for gears 3 and 4 but you dont know how far over to put it. the way i did it was i cut this shape out:
over lap the second shape with the first one and then slide the second shape bacvk and forth until you get the proper distance for the shifter to move laterally. then clamp the two pieces together or glue them if necessary. this will leave you with a shape that resembles the following:
obviously you need to duplicate this for 5th and 6th gear and then make a slot for reverse.
once you are done you can attach this piece and make sure the clearances are correct for every gear. once that is determined, you need to make precise measurements and then draw the shape onto a piece of aluminum. cut the shape out with your dremel tool and drill holes in the plate and mount it to your floor molding piece. you will never mis shift again.
Old Jun 28, 2006 | 08:49 PM
its ok you didnt mess this thread up, but nice ideal
Old Jun 28, 2006 | 11:32 PM
J-Brooks's Avatar
idea
Old Jun 30, 2006 | 02:27 PM
RC000E's Avatar
Default Re: creative ideals? (J-Brooks)
No IDEARS either....
Old Jun 30, 2006 | 02:39 PM
Niles's Avatar
Default Re: creative ideals? (RC000E)
My "idear" was to convert a '96 prelude to RWD using tubular subframes and suspension geometry of my own design with a 'special' drivetrain.
Old Jun 30, 2006 | 04:24 PM
Mr.E.G.'s Avatar
Default Re: creative ideals? (Niles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Niles &raquo;</TD></TR><TR><TD CLASS="quote">My "idear" was to convert a '96 prelude to RWD using tubular subframes and suspension geometry of my own design with a 'special' drivetrain.
niles you never cease to amaze me. i would love to pick your brain about the suspension setup if you dont mind. i have been reading a ton of suspension classics, and i would like to see which approach you took.
NA_H22_Ej
Dec 17, 2007 05:45 PM
CiViC SiR
Feb 13, 2006 08:04 PM
*Boostwerks*
Apr 29, 2005 01:50 PM
MR_FBPEM1
13
Mar 1, 2005 01:55 AM
FR-MOB: ThE bEe GuY
Jan 30, 2005 09:09 PM
