quick question: tach problem
I just swapped in a d15b in my eg hatch and now with the car idling, the tach shows 0 rpm. Now i built this car from a shell, so i don't know the history of the gauge cluster (don't know if this was a previous problem). Now when I'm driving the tach is working, although probably not accurate. So I think its safe to say this isn't an electrical problem....right? Is there a way to adjust the tach? Any help would be greatly appreciated.
Hook anther tack up to see if it is in fact your cluster or not, otherwise you can hook up a scanner to see where your tach should read, pull off the needle and push it back on where it should be.
Check my sig I think I have a thread in there giving you directions how to do this, the one titled on how to reset your speedo or something like that.
ok I just noticed I took it out, so you'll have to search for threads I created in the past.
Here you go,
https://honda-tech.com/zerothread?id=851492
Here you go,
