SRP PISTON AND ROD ASSEMBLY
Old Jun 25, 2006 | 04:24 PM
Youlose1305's Avatar
Default SRP PISTON AND ROD ASSEMBLY
i have a set of srp pistons and a set of eagle rods.......how is the piston aligned with the rod when assembling??? need help asap
Old Jun 25, 2006 | 04:39 PM
zerovandez's Avatar
Default Re: SRP PISTON AND ROD ASSEMBLY (Youlose1305)
bearing tang/notches face toward the front of the ENGINE BAY(exhaust side). Install pistons with deeper valve cuts on INTAKE SIDE, or compare them to your stock pistons and install accordingly.
Old Jun 25, 2006 | 04:52 PM
Chiovnidca's Avatar
Default Re: SRP PISTON AND ROD ASSEMBLY (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">bearing tang/notches face toward the front of the ENGINE BAY(exhaust side). </TD></TR></TABLE>
Do you know why they should be installed that way?
Old Jun 25, 2006 | 05:03 PM
zerovandez's Avatar
Hell no I don't but if Earl says to install it that way, then I'd just take that advice and go with it.
Default Re: SRP PISTON AND ROD ASSEMBLY (Chiovnidca)
well i dont have the stock pistons i just bought a bare block
Old Jun 28, 2006 | 11:04 PM
how do these pistons go on here im still confused and i havent had time to just call srp.............????
Old Jul 1, 2006 | 09:53 PM
any info??
paulITR
Nov 9, 2007 10:47 AM
90teg
Dec 29, 2004 07:47 AM
11psiTurboSI
Jan 1, 2004 11:19 AM
drjondurst
May 20, 2003 09:12 PM
snake01
Nov 26, 2002 06:49 PM
