wats better a b20 block or a b18b.
Old Jun 25, 2006 | 03:15 PM
latinf86's Avatar
Default wats better a b20 block or a b18b.
i want to buy a block to put with a b16 head and im not sure wich is better between a b20 and a b18
Old Jun 25, 2006 | 08:30 PM
import_honda1's Avatar
i would go wit the b18, but thats jus me.
Old Jun 25, 2006 | 08:36 PM
nappyroots827's Avatar
Default Re: (import_honda1)
b20 is more torquey but u can't rev as high...i hear their bottom ends suck, but im sure u can fix that with aftermarket product...personally id go b18, still torquey but u can rev em too
Old Jun 25, 2006 | 08:37 PM
crxnj's Avatar
Default Re: (nappyroots827)
i dont like the B20 unisleeve so i would go with the B18..
Old Jun 25, 2006 | 08:58 PM
Loserkidwac's Avatar
Default Re: (Mr.speaker)
B20 have thinner sleeves, its pretty much just a bored out LS block LS is 81mm abd the B20 is 84mm you will have more tourqe and you can build a decent B20/vtec with it but you will need to have some good tuning to keep it alive...the Ls will be a little safer to use, and the Ls or b20 vtecs are again no the most reliable because people don't build them properly so if you do your homework either one will be fine just spend the extra on tuning
Old Jun 25, 2006 | 09:16 PM
crxnj's Avatar
Default Re: (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">B20 have thinner sleeves, its pretty much just a bored out LS block LS is 81mm abd the B20 is 84mm </TD></TR></TABLE>
i dont know if the b20 has thinner sleeves..they look about the same or thicker to me,,,its the unisleeve design that makes those engines weak....There was an article i read a while back that described how honda got that 2.0L
Old Jun 25, 2006 | 09:33 PM
I always though it was just an LS bored to 84mm but I don't have any experience personally with a B20, Ls motors are to cheap and to common to go with anything else
Old Jun 25, 2006 | 09:45 PM
FernEF's Avatar
B18
Old Jun 25, 2006 | 09:57 PM
crxnj's Avatar
Default Re: (FernEF)
Look how thick the b20 sleeves are,,its just the unisleeve design sucks(for performance)
Old Jun 25, 2006 | 11:45 PM
Smokinsax's Avatar
The Boot
My personal expeirence with a B20B/VTEC was great...and still is. 3-4 years (stock B20/VTEC) reving to 8000 rpm + all day long. Maybe I just got lucky...
Now its built and feels just as good!
b20veghathc
12
Oct 5, 2010 07:16 AM
2ndgentegracer
Aug 11, 2006 03:16 PM
1995sir
Mar 19, 2006 09:02 AM
who00knows
Feb 20, 2003 02:18 PM
CTRwannaB
Jun 4, 2002 11:40 PM
