fuel cut-off switch question..
Old Jun 25, 2006 | 02:39 PM
JCracer723's Avatar
Default fuel cut-off switch question..
still kinda confused after reading many threads..
some mention that u "have" to use a relay.. some say you dont "have"to...
what i understand is that if you use a 25a or higher switch u dont need the relay..
which wire? yello/green or black??
came upon this thread and the guy says wich ever one u want to cut.. so im confused there..
https://honda-tech.com/zerothread?id=384077
so far this is what i understand... 25a or higher switch.. cut the yellow/green and walla urset.. am i right?
Old Jun 25, 2006 | 05:13 PM
JCracer723's Avatar
Default Re: fuel cut-off switch question.. (JCracer723)
anyone?
Old Jun 25, 2006 | 05:23 PM
5lugSlug's Avatar
i dont remember the wire i used, but i know i didnt use a relay and its been working fine (1yr stong)
Old Jun 25, 2006 | 05:27 PM
JCracer723's Avatar
Default Re: (i need a new username)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i need a new username &raquo;</TD></TR><TR><TD CLASS="quote">i dont remember the wire i used, but i know i didnt use a relay and its been working fine (1yr stong)</TD></TR></TABLE>
thanks for ur reply.. what amp switch did u use?
Old Jun 25, 2006 | 05:32 PM
5lugSlug's Avatar
i just went to radio shack and got a auto rocker switch (275-730)
Old Jun 25, 2006 | 05:34 PM
TurboLaxx's Avatar
I installed a fuel cutoff switch in my car. It's a yellow/green wire that runs down the drivers door sill and to the fuel pump under the rear seat. First i just put a switch in-line with the yellow/green wire and added extra wire to mount my hidden switch. I ended up blowing the fuel pump fuse like 5 times at random times. It was a bad situation. Finally i removed the extra wiring and put a relay in-line with my yellow/green wire. I ran the extra line to my switch. It's worked 100% since then and i've never had anymore blown fuses. I highly recommend using a relay cause it's only like $6 and you can hide everything better that way.
Here's the most awesome honda/acura security site you'll ever see. It was put together be a guy that's on the forums. It has wire color maps, detailed pictures, and he gives excellent pointers and tips about how to make a car virtually impossible to steal. It has a menu in the upper right to find all the good stuff. Check it out.
http://www.vsracing.net/~suspended/index.html
ill phil's Avatar
Can't remember what wire to use, but a generic toggle/rocker switch will work.... side note- definitely do this, someone attempted to steal my hatch a long time ago and they only got it about 25 feet with the gas in the lines. The switch saved my car and lots of hassle.
Old Jun 25, 2006 | 05:43 PM
JCracer723's Avatar
Default Re: (ill phil)
i got a 30a switch .. its recomended that a 25a minimum is used so i should be ok with no relay i hope.. i mean the fuel pump has a relay already doesnt it?
Old Jun 25, 2006 | 05:48 PM
1995Ex_Sedan's Avatar
Use this. It works.
http://www.courtlukens.com/Tech/cutoff_switch.htm
Old Jun 25, 2006 | 06:03 PM
ill phil's Avatar
Default Re: (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">i got a 30a switch .. its recomended that a 25a minimum is used so i should be ok with no relay i hope.. i mean the fuel pump has a relay already doesnt it? </TD></TR></TABLE>
yes, the main relay is what I wired off of. It's one that usually craps out during the summer on Hondas.
socalrex88
Mar 2, 2008 05:31 PM
blackrag
10
Jun 27, 2007 04:19 PM
TurboTurtleGSR
Jan 17, 2003 09:04 PM
Christine
Oct 1, 2001 08:38 AM
