Integra Type-R Fuel Pump Question
Old Jun 25, 2006 | 01:26 PM
Haleiwa-Brando's Avatar
Default Integra Type-R Fuel Pump Question
Old Jun 25, 2006 | 01:48 PM
RTW DC2R's Avatar
IIRC, the Walbro 255 HP I bought was for 97-01 Integras, so I would assume that different model years require no modification to mounting brackets or wiring. Double-check on that though, its been awhile.
Old Jun 25, 2006 | 10:50 PM
itr1244's Avatar
Default Re: Integra Type-R Fuel Pump Question (Haleiwa-Brando)
haleiwa brando what size is your warlbo pump now?
because i just got 255 lhp for my set up . i am wondering if it's over kill for my mild n/a set up
Old Jun 26, 2006 | 09:32 PM
itr1244's Avatar
interesting.
so. if you were me. i woudlnt install my new fuel pump ?
Old Jun 26, 2006 | 11:01 PM
mtber's Avatar
Default Re: Integra Type-R Fuel Pump Question (itr1244)
The walbro 255lph is not going to stress out your fuel system components.
If you are running a walbro 255lph or 255lph HP, it may alter your fuel pressure which will alter your injector flow, hence make your car run richer etc.
You should simply run the proper fuel pump / regulator / fuel pressure & ecu for your setup.
Old Jun 26, 2006 | 11:05 PM
itr1244's Avatar
Default Re: Integra Type-R Fuel Pump Question (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">The walbro 255lph is not going to stress out your fuel system components.
You should simply run the proper fuel pump / regulator / fuel pressure & ecu for your setup. </TD></TR></TABLE>
would 255 lph / 255 lph HP over kill for n/a cars?
Old Jun 26, 2006 | 11:09 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">would 255 lph / 255 lph HP over kill for n/a cars?</TD></TR></TABLE>
IMO, it would be overkill due to the fact that you do not need that much lph for a sub 250 whp vehicle. But if the pump is already installed in the vehicle & the vehicle's fuel pressure is at a proper static pressure, the pump will not harm anything.
Old Jun 26, 2006 | 11:13 PM
RTW DC2R's Avatar
ditto. I ran my stock pump on my previous all motor setup, made about 210whp with no issues on 310cc injectors and AEM EMS. then I also ran a 255 walbro on a mostly stock ITR motor with stock injectors and ECU and it ran fine. would be a good idea to have a wideband and adjust fuel pressure accordingly.
95ITRJDM
Apr 10, 2011 06:09 AM
civicjoe
Mar 5, 2008 12:40 PM
1SlowSi
Mar 1, 2004 08:50 PM
