question about tires
hi guys! I have several questions. First, do tires make loud noises while drive if the treads is uneve (some are lower than others)? Reason why I ask this is because I didn't changed my shocks for long time and due to that, I was told it causes my tires tread to be uneven. Looking from several feets away, my two back tires looks pretty weird.
Second, is it necessary to change the head gasket or whatever that thin metal thing call that goes between the header and engine?
Lastly, after installing my new Tokico shocks, I don't know if I adjust it right or not but my car seem to rumble or shakes a little hard while go over rough roads or dips, etc....what you guys think causing this hard vibration to my car?
Thanks for all the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suken19 »</TD></TR><TR><TD CLASS="quote">Second, is it necessary to change the head gasket or whatever that thin metal thing call that goes between the header and engine?
There is no need to change the gasket for no reason. If there is a leak, or you are getting signs of a blowen head gasket then yes you need to swap it out. But it is not a geneal maintance item.
azian21485
10
Jul 13, 2004 06:46 AM
