Do I need a block girdle? DID SEARCH
Well, I did a search but it was inconclusive. I have a B18B getting GE sleeves, JE or Endyn pistons, eagle rods, TURBO. Looking for 350+ HP. Do I need a block girdle? I am not planning on high revs, just high boost. Someone set this straight once in for all. It is $400 I could use on something else if I do not need it. Thanks,
high revs yes
if not then no.
just make sure you balance everything.
if not then no.
it good to tie in block girlde to keep everyhting in tact at higher revs. Its not really necessary if you keep a stock like configuration. But for 270 for a block girdle i would getone.
Info for you to consider
https://honda-tech.com/zerothread?id=153009
and
https://honda-tech.com/zerothread?id=153011
Both are girdle related
and
LoSt is BlaCk
Aug 12, 2003 10:39 AM
BlwnBlue
Jan 19, 2002 08:44 AM
