need some help replaceing my throw out bearing, not a noob, its fuckin stuck
Old Jun 24, 2006 | 05:28 PM
WolfGod's Avatar
Default need some help replaceing my throw out bearing, not a noob, its ****** stuck
like the title says, im no noob to this, i've done a few honda clutch jobs and changed the TO bearings in them while i was at it.. but mine i cant get out.. the shaft the clutch arm is on doesnt want to come out of the transmission, the only thing i can think of is the tranny is still in the car
i really dont want to pull the tranny so if anyone knows of a way that will get it out without pullin the tranny i'd appriate it alot
its a D16Z6 swap into an EF hatch, the motor is out of the car sitting in my garage ready to be put back in and i wanna change this before im ready to reinstall
any opinions are welcome
anyone who says pull the tranny for no other reason then its easier to work on, i dont care, unless it absolutely cant be helped, the tranny is staying in the car
Old Jun 24, 2006 | 05:50 PM
2poor2tune's Avatar
do you mean it is still connected? if so there is a bolt holding the clutch cable fork in there. i dont know how you would change it out without oulling the tranny.
Old Jun 24, 2006 | 05:56 PM
WolfGod's Avatar
Default Re: (2poor2tune)
this is how it sits right now, there isnt any bolts holding the shaft im talking about in place except one inside the tranny right under the throw out bearing
the cable arm just doesnt want to come out so i can take the throw out bearing out
Old Jun 24, 2006 | 06:25 PM
civicwagonman's Avatar
dont need to pull the arm. take a 90 degree pick,and release the spring on the right and left of the throwout bearing, then it will come right out.
Old Jun 24, 2006 | 06:28 PM
WolfGod's Avatar
Default Re: (civicwagonman)
could have swore i took the shaft out last time i did a clutch on my friends honda... was a couple years ago tho so maybe im wrong, thanks for the tip
Old Jun 24, 2006 | 06:53 PM
jeremydde's Avatar
Default Re: (WolfGod)
You don't have to take the shaft out. I have changed the throw-out bearings both ways. Just pry the spring loose with a small tool and reassemble that way again.
Old Jun 24, 2006 | 08:38 PM
UltimX's Avatar
Default Re: (jeremydde)
Can't you just move the shaft so the throw out bearing moves out, then replace it?
Old Jun 24, 2006 | 08:48 PM
WolfGod's Avatar
Default Re: (UltimX)
the TO bearing is held onto the tranny shaft by a wire/spring that goes around the arm shaft, so no
but i wasnt sure if the wire had hooks that go into the sides of the TO bearing or not so i didnt try to just unhook it, i wanted to take that shaft out but since i cant i'll go up in a bit and unhook it and see how it goes
Old Jun 24, 2006 | 09:37 PM
bigcalidave's Avatar
You have no motor in there, why are you scared to drop the trans, it's like 5 minutes of work... Less time than it took to post this here.
Old Jun 24, 2006 | 10:22 PM
WolfGod's Avatar
Default Re: (bigcalidave)
im not scared to drop it, i fractured something in or just below my shoulder and i dont have a cherry picker, come-along, or tranny jack to pull or drop it with
so i'd really prefer not to drop it as i'd majorly expletive up my arm, get my wife pissed at me, which would in turn make it harder for me to get ***** which is something i dont want
so unless your prepared to get me *****, the tranny stays where it is
Old Jun 24, 2006 | 10:35 PM
lol, cool.
Old Jun 25, 2006 | 05:03 AM
how do you plan on putting the motor back in if you have a screwed arm and no tools to lift it with? and did you get it changed yet?
Old Jun 25, 2006 | 01:36 PM
WolfGod's Avatar
im bribeing some buddys with beer and pizza to lift it for me, after that im putting it together
hopefully someone will bring a cherry picker or something.. if nothing else i'll go buy a come along and attatch it to the ceiling of my garage over my car
well i didnt notice that theres a diffrence in the TO bearings, i'd need to modify the TO bearing that got sent with the kit to make it work... so i think im just gonna reuse the old one
Modified by WolfGod at 6:05 PM 6/25/2006
LilJonWask
Oct 31, 2006 04:43 AM
teler86
Jan 24, 2006 06:30 PM
bambbrose
Dec 12, 2004 10:17 PM
spladam02
Dec 9, 2002 06:05 AM
Juantay19
Apr 5, 2002 04:37 AM
