intake lines and hoses??
Old Jun 24, 2006 | 02:58 PM
JjuuN R's Avatar
Default intake lines and hoses??
ok, to make a long story short, i'm putting my stock ITR motor in (8000mi) for a little while as the built motor is getting some new vavles and pistons. got the stock one in with new oils of course for the motor/tranny, as i'm putting on my CAI i see lines and hoses everywhere. my question is this:
there's obviously a hose going from the valve cover to the intake... off of that hose/line theres 2 splits that lead elsewhere. 1: hose connecting to the TB. 2: hose connecting to the actual head right under the fuel rail. i have looked this over in the past as it's my first time noticing it. do they NEED to be there, and if not do i need plug them up with something?
Old Jun 24, 2006 | 03:53 PM
KOALA YUMMIES's Avatar
Default Re: intake lines and hoses?? (JUN.R)
Coolant obviously runs though those lines, to help heat the throttle body to prevent the throttle plate from sticking while cold (IIRC)? You can loop them or plug them (I still have mine hooked up like factory) however some people dont run them. As far as the need for them? Prob not totally necessary, especially out where you live There are a couple threads on this but I forget what they're titled under.
Old Jun 24, 2006 | 04:15 PM
JjuuN R's Avatar
Default Re: intake lines and hoses?? (KOALA YUMMIES)
ok i got it, i'm just going to run hose from the valve cover > intake arm. and hose from the bottom of the TB > back of the head. almost like stock i guess just eliminating that 4 way metal line... ??
I B BANGGIN
Aug 12, 2007 04:32 PM
Evolution-93-Ex
13
Mar 7, 2006 01:04 PM
EF8IGHT
Nov 8, 2005 07:53 AM
prayludin
Mar 30, 2005 12:03 PM
1bar
Mar 27, 2003 08:09 PM
