gt30 with .60 A/R
Old Jun 24, 2006 | 11:33 AM
boostedB16a1's Avatar
Default gt30 with .60 A/R
is it possible for making 9500 rmp with a built block if i am gonna use this turbo without loosing power on the high rpm's?
greats
Old Jun 24, 2006 | 11:58 AM
Wideopentuning's Avatar
Default Re: gt30 with .60 A/R (boostedB16a1)
I would use the larger housing. You can feel the top end taper when using the .63 housings when running over 15 psi on the 3071R and he 3076R. FWIW I tuned an SRT4 with the 3076 and it still managed 402 whp on pump gas although this was at 23 psi. I think the 400 whp mark would have been hit sooner with the larger turbine housing.
Old Jun 24, 2006 | 12:04 PM
Default Re: gt30 with .60 A/R (Wideopentuning)
ok thx
but i already have the turbo
Old Jun 24, 2006 | 12:12 PM
96 GSR-T's Avatar
Housings are under $200 dyno the car and if the powerband is not to your liking, buy the bigger housing
Old Jun 24, 2006 | 12:46 PM
TheShodan's Avatar
Moderator
Default Re: gt30 with .60 A/R (96 GSR-T)
The housing is only part of a step process in obtaining the powerband. simply switching housings can help with the process, but its the wheels that make the full change in characteristics.
Old Jun 24, 2006 | 12:53 PM
Default Re: gt30 with .60 A/R (TheShodan)
ok thx guys
Old Jun 24, 2006 | 12:55 PM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">The housing is only part of a step process in obtaining the powerband. simply switching housings can help with the process, but its the wheels that make the full change in characteristics.</TD></TR></TABLE>
The cheapest way is the housing, you start changing wheels you are talking big bucks.... might as well sell the turbo and get another one.
TURKISHFORCE
Dec 18, 2006 06:40 AM
Importracer_001
Nov 22, 2004 06:21 AM
yusoslo
Apr 27, 2004 07:03 AM
MIKES
Nov 18, 2003 06:40 AM
ASHY-ELBOW
Nov 4, 2002 10:15 PM
