RL timing belt
Some folks do not want to work on Honda crank bolts because they can be a serious pain to get out, but if you are a regular Honda guy then you probably have the special crank pulley socket and an extra long cheater bar to bust the crank bolt loose. I just crank up the shop air and break out the 3/4 inch impact, dont forget, the engine turns the wrong way to use the starter to bust the bolt loose like on most cars. The bolt is still left hand thread and still comes out CCW direction.
