Head gasket question
ok i have a eg civic with and ls swap. it has a built bottom end (pistons, rods, ect.....) and a t3t4 turbo. i want to get a cometic head gasket to finish the build for now but dont know the thickness i should get..... any suggesions???
You don't have to go metal head gasket. I mean head gaskets only blow for a reason. Over heating. Other than that a head gasket can last forever. So like they said. Just pick up an OEM head gasket and stick with that. It's cheaper and serves the same purpose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhondacivic »</TD></TR><TR><TD CLASS="quote">The only reason to go with anything other than stock is to change the compression. And if you built the bottom end you are probably happy with the compression.</TD></TR></TABLE>
This is ture^...OEM FTW!
