looking for a new suspension for my EF
Old Jun 24, 2006 | 12:35 AM
gyrmaersk's Avatar
Default looking for a new suspension for my EF
Okay, so I am planning to get rid of my KYB/Ground Control setup in favor of a TRUE coil over, for separate ride height and adjustment. I looked at Tein and they do not offer a true coil over setup for our EFs- what do you recommend? Looking for something that I can tune for the weekends at the track..
Old Jun 24, 2006 | 12:59 AM
nihkon's Avatar
Default Re: looking for a new suspension for my EF (gyrmaersk)
They offer 3 different models for the EF's
http://www.tein.com/honda.html
Old Jun 24, 2006 | 01:10 AM
Daisy EE8's Avatar
Default Re: looking for a new suspension for my EF (nihkon)
I don't know if they are available in the US, but KW makes some pretty good coilovers.
There are two variants for the EF. All coilovers are stainless steel - they call it inox line.
V1 not adjustable in damping (I have this one)
V3: adjustable damping technology -rebound and compression damping
Ah - I got it:
http://www.kw-suspension.com/e...x.php
http://www.kw-suspension.com/e...e=all
I actually don't know which EF you own. The cart shows the german (european) Carcodes. If you need help, ask me.
Old Jun 24, 2006 | 04:11 AM
aXhatch's Avatar
Default Re: looking for a new suspension for my EF (Daisy EE8)
d2 racing.
they are awesome IMO
i rock em!
Old Jun 24, 2006 | 07:05 AM
Tyson's Avatar
whats a TRUE coilover? whats FALSE about anything else?
Old Jun 24, 2006 | 07:16 AM
Newark Built's Avatar
* B A N N E D *
Default Re: looking for a new suspension for my EF (Tyson)
all this talk about coilovers makes me laugh.
you ever seen coilovers get properly tuned.
Seeing people adjust their coilovers by eye
screws with the over all handleing of the car.
You gatta load ( if i remember right) equal weight onto each coilver, or in better terms, distribute the weight accordingly.
You might as well be rockin cut springs ( not really )
just my .02
Old Jun 24, 2006 | 07:18 AM
ShiroX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">whats a TRUE coilover? </TD></TR></TABLE>
He probably means an integrated unit. Where the thread perch is part of the body allowing for "dual adjustment".
Honestly, theres no better setup than Neuspeed Koni Yellows and GC w/ custom spring rate.
Neuspeed Koni is 20mm shorter which compensates for droop if you decide to run the car extra low....if that is still not enough you always get the GC top hat to help further
also the Neuspeed Koni has (3?) points for you to mount the GC unit thus similating "double adjustment"
and finally USA lifetime w/ in house shock dyno, custom valving option.
Ive used 3 different "TRUE" coilover systems and have not found any additional benefits.
Dont buy into 32click adj...
Old Jun 24, 2006 | 07:32 AM
CRX Toad's Avatar
Default Re: looking for a new suspension for my EF (ShiroX)
GC/ Koni Yellow &gt; *
There is no such thing as a Neuspeed Koni Yellow. Neuspeed is just a retail front for Koni to sell there shock out of.
Old Jun 24, 2006 | 07:41 AM
saltypants's Avatar
Default Re: looking for a new suspension for my EF (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">GC/ Koni Yellow &gt; *
There is no such thing as a Neuspeed Koni Yellow. Neuspeed is just a retail front for Koni to sell there shock out of. </TD></TR></TABLE>
I have no idea whether they do or not but they claim to here.
http://www.neuspeed.com/produc...=1137
Old Jun 24, 2006 | 07:42 AM
CRX Toad's Avatar
Default Re: looking for a new suspension for my EF (saltypants)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saltypants &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.neuspeed.com/produc...=1137</TD></TR></TABLE>
I understand that. They may have a relationship in some capacity but it is all Koni. Neuspeed is not branded on the shock either. I do understand what you are saying.
Old Jun 24, 2006 | 07:56 AM
saltypants's Avatar
Yeah I understand that it is a Koni shock as well and doesn't have Neuspeed written on it anywhere.
I'm just talking about the description, specifically this part:
The NEUSPEED/Koni shocks also feature an adjustable spring perch to level the car (5 machined grooves on the shock body for 5 positions of adjustment) - the most desirable handling position, as well as, a 20mm shorter droop length for use with lowering springs.
So if I ordered them from kteller they would be the same with 5 positions and the 20mm additional droop length?
Old Jun 24, 2006 | 10:40 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">There is no such thing as a Neuspeed Koni Yellow. Neuspeed is just a retail front for Koni to sell there shock out of. </TD></TR></TABLE>
neuspeed does indeed offer a different shock than the regular koni yellow. it has a 10mm piston travel limiter and extra perch positions that the normal koni yellows do not offer. its made by koni of course, and is otherwise the same as a koni yellow, but its a special spec not normally offered.
Old Jun 25, 2006 | 04:12 AM
91SiZ6's Avatar
^^Which is why it's the Neuspeed/Koni Yellow.
I'm looking at the Neuspeed/Koni Race package or Omni coilovers for my next suspension.
Old Jun 25, 2006 | 05:39 AM
ShiroX's Avatar
Its a redesigned Koni Yellow for Neuspeed which i think is an upgrade over the standard Koni Yellow...but every else calls it Neuspeed Koni, sorry if there was any confusion
again quoted from http://www.neuspeed.com
"The NEUSPEED/Koni shocks also feature an adjustable spring perch to level the car (5 machined grooves on the shock body for 5 positions of adjustment) - the most desirable handling position, as well as, a 20mm shorter droop length for use with lowering springs."
Old Jun 25, 2006 | 05:44 AM
CRXBart's Avatar
Get the SPSS twin valves from Redshiftracing.com
Old Jun 25, 2006 | 05:50 AM
ShiroX's Avatar
Default Re: looking for a new suspension for my EF (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">
Get the SPSS twin valves from Redshiftracing.com </TD></TR></TABLE>
the only downside to the SPSS twin valves is they do not carry Koni's "lifetime" warranty because its a "race" application....lol sounds like a racial thing
can anyone else confirm this?
Old Jul 9, 2006 | 11:59 AM
gyrmaersk's Avatar
I tried using redshiftracing.com as a link, but it didn't work. Where else can I find them?
Old Jul 9, 2006 | 02:05 PM
GoFastTshirts.com's Avatar
the new omni ef coilovers are sweet !!!
Old Jul 9, 2006 | 02:27 PM
trrbl1bmx's Avatar
Omni, Buddy Club, or the old T1R
Old Jul 9, 2006 | 03:21 PM
Blanket Jackson's Avatar
I heard the D2's are good.
I want to rock some Omnis but have to spend the money on my D16Y8
K7-1Ktrevor
Northwest (Sales)
Sep 2, 2010 10:25 PM
efpride
Suspension & Brakes
Oct 18, 2005 10:17 PM
Andy R
Jul 5, 2005 10:05 AM
strict 9 ef
Dec 22, 2003 08:15 AM
jdmjunky
Oct 7, 2003 02:01 PM
